C6Run compile problem
I am trying to use the DSP on BeagleBoard-XM.
I am installing C6Run which can compile my DSP code.
I am following the wiki —
http://processors.wiki.ti.com/index.php/Getting_Started_With_C6EZRun
I followed all the steps for Stand-alone Setup. I could compile the DSP-side back-end C6Run library using make dsp_libs.
In the next step I am trying to build the ARM-side back-end C6Run library using
make gpp_libs. It gives me following error —
make[1]: Entering directory /home/radhika/BeagleBoard/C6Run_0_97_03_03/build' make[2]: Entering directory /home/radhika/BeagleBoard/C6Run_0_97_03_03/build/gpp_libs’
make[2]: Leaving directory /home/radhika/BeagleBoard/C6Run_0_97_03_03/build/gpp_libs' make[2]: Entering directory /home/radhika/BeagleBoard/C6Run_0_97_03_03/build/gpp_libs’
make[3]: Entering directory /home/radhika/BeagleBoard/C6Run_0_97_03_03/build' __Building DSPLink GPP-side userspace libraries (be patient)...gmake[4]: *** No rule to make target /bin/arm-none-linux-gnueabi-gcc’. Stop.__
make[3]: *** [gpp_libs] Error 2
make[3]: Leaving directory /home/radhika/BeagleBoard/C6Run_0_97_03_03/build' make[2]: *** [/home/radhika/BeagleBoard/C6Run_0_97_03_03/dsplink_linux_1_65_00_03/dsplink/gpp/export/BIN/Linux/OMAP3530/DEBUG/dsplink.lib] Error 2 make[2]: Leaving directory /home/radhika/BeagleBoard/C6Run_0_97_03_03/build/gpp_libs’
make[1]: *** [gpp] Error 2
make[1]: Leaving directory `/home/radhika/BeagleBoard/C6Run_0_97_03_03/build’
make: *** [gpp_libs] Error 2
I have no clue why I am getting that error ? Does anybody have idea about this ?
Regards
Radhika
I haven’t looked at the wiki page yet (slow web access), but what all did you download and configure? It seems like you don’t have the ARM compiler configured the way the Makefile wants you to have it.
Hi!
I have also a similary error when I make gpp_libs:
sudo make gpp_libs
[sudo] password for linux_pdci:
make[1] : on entre dans le répertoire « /home/linux_pdci/TI/C6EZRun/
C6Run_0_97_03_03/build »
make[2] : on entre dans le répertoire « /home/linux_pdci/TI/C6EZRun/
C6Run_0_97_03_03/build/gpp_libs »
make[2] : on quitte le répertoire « /home/linux_pdci/TI/C6EZRun/
make[3] : on entre dans le répertoire « /home/linux_pdci/TI/C6EZRun/
patient)...gmake[5]: /home/linux_pdci/TI/C6EZRun/C6Run_0_97_03_03/bin/-
gcc : commande introuvable
gmake[5]: *** [/home/linux_pdci/TI/C6EZRun/C6Run_0_97_03_03/
dsplink_linux_1_65_00_03/dsplink/config/BUILD/CFG_system.c.deb] Erreur
127
gmake[4]: *** [objdeb] Erreur 2
make[3]: *** [gpp_libs] Erreur 2
make[3] : on quitte le répertoire « /home/linux_pdci/TI/C6EZRun/
make[2]: *** [/home/linux_pdci/TI/C6EZRun/C6Run_0_97_03_03/
dsplink.lib] Erreur 2
make[1]: *** [gpp] Erreur 2
make[1] : on quitte le répertoire « /home/linux_pdci/TI/C6EZRun/
make: *** [gpp_libs] Erreur 2
I think that it's my makefile or my Rules.mak that is the problem
because the compiler is correctly installed.
Thanks in advance :slight_smile:
