Hi ,
I am working on program to grab the frames from camera(logitech) and
save frames as images continuously , when I compile and run on linux
machine its working fine.I have compiled OpenCV library and written
program using open CV lib functions.
When I try to run on beagle board I am getting error like
Camera decode error(-1) : Corrupt JPEG data
Thank you,
Srikanth
Can i have a look on your application to comment more
Hi suresh,
Initial 3 to 6 frames are decoded and stored successfully,after that I
Camera decode error(-1): JPEG decode error.
// A Simple Camera Capture Framework
int main() {
int i = 0 ;
IplImage *frame , *frames[10];
char image[50];
CvCapture* capture = cvCaptureFromCAM( -1 );
if( !capture ) {
fprintf( stderr, "ERROR: capture is NULL \n" );
getchar();
return -1;
for (i = 0 ; i < 10 ; i++) {
// Get one frame
frame = cvQueryFrame( capture );
if( !frame ) {
fprintf( stderr, "ERROR: frame is null...\n" );
getchar();
break;
// Do not release the frame!
if( i < 10 ) {
frames[i] = cvCloneImage( frame );
sprintf( image, "%d.png", (i+1) );
cvSaveImage( image, frames[i],0);
if( (cvWaitKey(1000) & 255) == 27 ) break;
cvReleaseCapture( &capture );
cvDestroyWindow( "mywindow" );
return 0;
Thank you,
Srikanth
