CAN Bus Interface
Has anyone connected the Beagleboard to a CAN Bus interface?
What hardware / Linux drivers / CAN Bus stack did you use? Was it
CANopen compliant?
The Craneboard has a CAN bus interface, will the same Linux drivers /
stack work on that too?
Andrew
The craneboards CAN interface works with the socketcan stack and can do up to 1MHz.
regards,
Koen
