Can I buy the MCP memory of Micron?
Hello.
I'd like to re-design board based on beagle board.
Most of problem is solved but the MCP PoP package memory is remained
to a headache.
How can I buy the Micron 29C2G24MAKLAJG-6IT ES memory?
How can I get the datasheet?
If anyone know the solution about these problem, please share the
knowledge.
Thanks.
You will need to contact your local Micron representative or distributor for this information. The datasheet should be available from the Micron website.
If you will tell me where you are located, I will see if I can find a contact for you in your area.
