hi Robert,
i wanted to ask how you did fixed the problem? was the problem with the
usb-to-serial converter or bad cabling, or anything else?
i have the same problem with the same usb-to-serial converter with the
pl2303 chip and the same vendor and product id but from an other
manufacturer (M-CAB) that i bought.
thank you in advance.
cheers,
bugra.
rather than mess around with a full-blown port replicator to connect
to the console on my BB, i picked up a simpleUSB-serial converter and
am trying to use that to go fromUSBon my laptop to the serial port
at the other end, then a gender changer, and finally to the serial
(AT/Everex workalike) cable.here's the converter cable:
http://www.prolific.com.tw/eng/Products.asp?ID=59
and when i plug it into my fedora 9 system, i see this in
/var/log/messages;Mar 14 18:18:44 localhost kernel:usb2-1: new full speedUSBdevice using
uhci_hcd and address 69
Mar 14 18:18:45 localhost kernel:usb2-1: configuration #1 chosen from
1 choice
Mar 14 18:18:45 localhost kernel: pl2303 2-1:1.0: pl2303 converter
detected
Mar 14 18:18:45 localhost kernel:usb2-1: pl2303 converter now attached
to ttyUSB0
Mar 14 18:18:45 localhost kernel:usb2-1: NewUSBdevice found,
idVendor=067b, idProduct=2303
Mar 14 18:18:45 localhost kernel:usb2-1: NewUSBdevice strings: Mfr=1,
Product=2, SerialNumber=0
Mar 14 18:18:45 localhost kernel:usb2-1: Product:USB-Serial Controller
Mar 14 18:18:45 localhost kernel:usb2-1: Manufacturer: Prolific
Technology Inc.
