Can not ping my beaglebone
Was funny I had access to it via serial only just before, but then it stopped working when I reset my PC…
This is what looks like end of dmesg when I plug in my beaglebone:
[ 791.204073] usb 2-3: new high speed USB device using ehci_hcd and address 2
[ 791.436396] usb 2-3: configuration #1 chosen from 1 choice
[ 791.436591] hub 2-3:1.0: USB hub found
[ 791.436735] hub 2-3:1.0: 2 ports detected
[ 792.108249] usb 2-3.1: new high speed USB device using ehci_hcd and address 3
[ 792.302277] usb 2-3.1: configuration #1 chosen from 1 choice
[ 797.580120] usb 2-3.2: new high speed USB device using ehci_hcd and address 4
[ 804.256243] usb 2-3.2: device descriptor read/64, error -71
[ 804.679417] usb 2-3.2: configuration #1 chosen from 1 choice
[ 804.748943] usb0: register ‘cdc_ether’ at usb-0000:00:1d.7-3.2, CDC Ethernet Device, d2:dc:b1:bf:86:5f
[ 804.748981] usbcore: registered new interface driver cdc_ether
[ 815.308043] usb0: no IPv6 routers present
[ 953.288282] usb 2-3.2: USB disconnect, address 4
[ 953.288620] usb0: unregister ‘cdc_ether’ usb-0000:00:1d.7-3.2, CDC Ethernet Device
[ 959.628272] usb 2-3.2: new high speed USB device using ehci_hcd and address 5
[ 966.300147] usb 2-3.2: device descriptor read/64, error -71
[ 966.727437] usb 2-3.2: configuration #1 chosen from 1 choice
[ 966.735593] usb0: register ‘cdc_ether’ at usb-0000:00:1d.7-3.2, CDC Ethernet Device, 16:f6:fa:aa:0a:62
[ 976.892039] usb0: no IPv6 routers present
[ 1082.345780] wlan0: disassociating by local choice (reason=3)
[ 1107.505064] wlan0: authenticate with AP 94:44:52:80:ca:2a
[ 1107.507231] wlan0: authenticated
[ 1107.507238] wlan0: associate with AP 94:44:52:80:ca:2a
[ 1107.511248] wlan0: RX AssocResp from 94:44:52:80:ca:2a (capab=0x411 status=0 aid=1)
[ 1107.511255] wlan0: associated
Let me try “a shot in the dark”: (don´t know if this expression makes sense in English hahaha)
After plug in you beaglebone wait few moments, check if you see dmesg messages similar this:
(don´t bother with the numbers and MAC address, just see the device name highlighted above)
If you have those messages after plug the beagle try this:
sudo ifconfig usb0 192.168.7.1
After that check dmesg again and try serial console access.
This is a rough guess but recently I experienced serial console freeze while not enabling Ethernet CDC device at PC. Of course that symptom started after I recompiled the kernel myself and is probably not your case but try it may worth.
