Can not ping my beaglebone
The one above is from my ubuntu I installed on my beaglebone. This is from the original card supplied/Angstrom.
[ 1589.775247] usb 2-3: USB disconnect, address 2
[ 1589.775258] usb 2-3.1: USB disconnect, address 3
[ 1589.775713] usb 2-3.2: USB disconnect, address 5
[ 1589.776268] usb0: unregister ‘cdc_ether’ usb-0000:00:1d.7-3.2, CDC Ethernet Device
[ 1614.236094] wlan0: no probe response from AP 94:44:52:80:ca:2a - disassociating
[ 1615.390094] wlan0: authenticate with AP 94:44:52:80:ca:2a
[ 1615.392572] wlan0: authenticated
[ 1615.392579] wlan0: associate with AP 94:44:52:80:ca:2a
[ 1615.396555] wlan0: RX ReassocResp from 94:44:52:80:ca:2a (capab=0x411 status=0 aid=1)
[ 1615.396559] wlan0: associated
[ 1645.568070] usb 2-3: new high speed USB device using ehci_hcd and address 6
[ 1645.800300] usb 2-3: configuration #1 chosen from 1 choice
[ 1645.800414] hub 2-3:1.0: USB hub found
[ 1645.800517] hub 2-3:1.0: 2 ports detected
[ 1646.468157] usb 2-3.1: new high speed USB device using ehci_hcd and address 7
[ 1646.662176] usb 2-3.1: configuration #1 chosen from 1 choice
[ 1688.708171] usb 2-3.2: new high speed USB device using ehci_hcd and address 8
[ 1689.101674] usb 2-3.2: configuration #1 chosen from 1 choice
[ 1689.143700] Initializing USB Mass Storage driver…
[ 1689.144803] scsi6 : SCSI emulation for USB Mass Storage devices
[ 1689.145040] usbcore: registered new interface driver usb-storage
[ 1689.145047] usb-storage: device found at 8
[ 1689.145051] usb-storage: waiting for device to settle before scanning
[ 1689.145055] USB Mass Storage support registered.
[ 1694.144375] usb-storage: device scan complete
[ 1694.156163] scsi 6:0:0:0: Direct-Access Linux File-CD Gadget 0316 PQ: 0 ANSI: 2
[ 1694.156575] scsi 6:0:0:1: Direct-Access Linux File-CD Gadget 0316 PQ: 0 ANSI: 2
[ 1694.157351] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 1694.157562] sd 6:0:0:1: Attached scsi generic sg3 type 0
[ 1694.208083] sd 6:0:0:0: [sdb] 144522 512-byte logical blocks: (73.9 MB/70.5 MiB)
[ 1694.220085] sd 6:0:0:1: [sdc] 5590620 512-byte logical blocks: (2.86 GB/2.66 GiB)
[ 1694.324686] sd 6:0:0:0: [sdb] Write Protect is off
[ 1694.324693] sd 6:0:0:0: [sdb] Mode Sense: 0f 00 00 00
[ 1694.324697] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1694.434718] sd 6:0:0:1: [sdc] Write Protect is off
[ 1694.434729] sd 6:0:0:1: [sdc] Mode Sense: 0f 00 00 00
[ 1694.434733] sd 6:0:0:1: [sdc] Assuming drive cache: write through
[ 1694.554691] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1694.554700] sdb:
[ 1694.674719] sd 6:0:0:1: [sdc] Assuming drive cache: write through
[ 1694.674734] sdc: unknown partition table
[ 1694.844693] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1694.844701] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 1695.104685] sd 6:0:0:1: [sdc] Assuming drive cache: write through
[ 1695.104692] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[ 1697.032208] kjournald starting. Commit interval 5 seconds
[ 1697.032217] EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
[ 1697.252803] EXT3 FS on sdc, internal journal
[ 1697.252810] EXT3-fs: recovery complete.
[ 1697.252816] EXT3-fs: mounted filesystem with ordered data mode.
