An error occurs when I was typing this sentence. (apt -get update)
I use Ubuntu 14.04 on BBB
Please let me know the solution.
“192.168.7.2”
So either “setup” internet connections sharing or Just plug in the ethernet connector your dhcp-router…
Looks like a network connectivity issue. From your BBB can you ping ports.ubuntu.com? It looks like you’re using the static IP address that comes pre-canned with BBB and so you’ll probably need to set up some sort of routing gateway that makes sense for your network setup.
Scott
It also connected the same.
"same" ??
sudo ifconfig -a
well neither his host OR BBB had internet access . . . if you note the output about 1/4 way down, he logged out of his ssh session. Then just says “err . . .”
