cannot bitbake console/x11-image
I am using the latest OE. Everything is up-to-date.
When I try to bitbake console-image I get these errors:
NOTE: package shared-mime-info-native-0.51-r0: task do_compile: started
ERROR: function do_compile failed
ERROR: see log in
/home/developer/oe/tmp/work/i686-linux/shared-mime-info-native-0.51-r0/temp/log.do_compile.19953
NOTE: Task failed:
NOTE: package shared-mime-info-native-0.51-r0: task do_compile: failed
ERROR: TaskFailed event exception, aborting
NOTE: package shared-mime-info-native-0.51: failed
ERROR: Build of
/home/developer/oe/openembedded/packages/shared-mime-info/shared-mime-info-native_0.51.bb
do_compile failed
ERROR: Task 4024
(/home/developer/oe/openembedded/packages/shared-mime-info/shared-mime-info-native_0.51.bb,
do_compile) failed
NOTE: Tasks Summary: Attempted 1218 tasks of which 717 didn't need to
be rerun and 1 failed.
ERROR: '/home/developer/oe/openembedded/packages/shared-mime-info/shared-mime-info-native_0.51.bb'
failed
OE:beagleboard developer@big-ubuntu:~/oe/opt$ cat
NOTE: make
Making check in po
make[1]: Entering directory
`/home/developer/oe3/tmp/work/i686-linux/shared-mime-info-native-0.51-r0/shared-mime-info-0.51/po'
rm -f missing notexist
srcdir=/home/developer/oe/tmp/work/i686-linux/shared-mime-info-native-0.51-r0/shared-mime-info-0.51/po
/home/developer/oe/tmp/staging/i686-linux/usr/bin/intltool-update -m
The following files contain translations and are currently not in use. Please
consider adding these to the POTFILES.in file, located in the po/ directory.
me/developer/oe/tmp/work/i686-linux/shared-mime-info-native-0.51-r0/shared-mime-info-0.51/po/../freedesktop.org.xml.in
me/developer/oe/tmp/work/i686-linux/shared-mime-info-native-0.51-r0/shared-mime-info-0.51/po/../update-mime-database.c
If some of these files are left out on purpose then please add them to
POTFILES.skip instead of POTFILES.in. A file 'missing' containing this list
of left out files has been written in the current directory.
if [ -r missing -o -r notexist ]; then \
    exit 1; \
  fi
make[1]: *** [check] Error 1
make[1]: Leaving directory
make: *** [check-recursive] Error 1
FATAL: oe_runmake failed
What can I do?
Thanks - Robert
it is a problem with libxml and zlib. ZLib cannot create gzopen64 without two #define values and libxml defines only one of them.
I have attached the patch and bb + inc files that i used to get around the issue. Replace the inc and bb files in OE/openembedded/packages/libxml and put the patch file in files directory in the same path.
santosh
libxml_gzopen64.patch (276 Bytes)
libxml2-native_2.7.2.bb (87 Bytes)
libxml2.inc (850 Bytes)
This di not solved the problem. The error remains the same.
Robert
This did not solved the problem. The error remains the same.
I solved it by installing the glib and libxml developer packages on my
host system.
Now I have a problem with the !native package:
NOTE: package shared-mime-info-0.51-r2: task do_install: started
ERROR: function do_install failed
ERROR: see log in
/home/developer/oe/tmp/work/armv7a-angstrom-linux-gnueabi/shared-mime-info-0.51-r2/temp/log.do_install.31068
NOTE: Task failed:
NOTE: package shared-mime-info-0.51-r2: task do_install: failed
NOTE: package shared-mime-info-0.51: failed
ERROR: Build of
/home/developer/oe/openembedded/packages/shared-mime-info/shared-mime-info_0.51.bb
do_install failed
ERROR: Task 1711
(/home/developer/oe/openembedded/packages/shared-mime-info/shared-mime-info_0.51.bb,
do_install) failed
cat /home/developer/oe/tmp/work/armv7a-angstrom-linux-gnueabi/shared-mime-info-0.51-r2/temp/log.do_install.31068
NOTE: make DESTDIR=/home/developer/oe/tmp/work/armv7a-angstrom-linux-gnueabi/shared-mime-info-0.51-r2/image
install
make: *** No rule to make target `install'. Stop.
The /home/developer/oe/tmp/work/armv7a-angstrom-linux-gnueabi/shared-mime-info-0.51-r2/image
folder is empty!?!?
Any ideas?
Robert
If anybody still has this issue ( I just came across this issue ):
after applying santosh's patches, you need to:
bitbake -c clean libxml2-native
bitbake -c compile libxml2-native
bitbake -c install libxml2-native
/Arne
Hmm, still not working here. The error is exactly the one from the
initial posting. I also see that the libxml patch is actually being
applied:
NOTE: package libxml2-2.7.2-r0: task do_patch: started
NOTE: Applying patch 'libxml_gzopen64.patch' (/home/test/angstrom/
openembedded/packages/libxml/files/libxml_gzopen64.patch)
NOTE: package libxml2-2.7.2-r0: task do_patch: completed
NOTE: package libxml2-2.7.2: completed
Still the exact same error remains ...
Any clues?
MoG
Hi!
applied:
Any clues?
I had the same issue, and the only way to solve it was to rebuild the whole system. Yep, that sucked, but cleaning/rebuilding only the mentioned packages did not work for me either. I guess that to many packages rely on those packages (zlib and libxml2)...
Stefan
I solved this by manually going to the build directory of shared-mime-
info and doing a "configure" and "make" there. Afterwards bitbake was
able to continue.
Ok, that only helped for the i686 part, the arm part still broke.
But i think i found something. I did notice, that these paths were
truncated:
They were truncated in my setup also. So i moved everything from /home/
harbaum
to /mnt and guess what? Now the build process passed shared-mime-info
without
errors ...
Hi all
has anyone solved this problem??
I met the same one. After downloading the patch provided by santosh,
it says
NOTE: Handling BitBake files: / (4995/6632) [75 %]ERROR: libxml2.inc:
1: unparsed line: '--- libxml2-2.7.2/libxml.h 2007-11-23
02:47:23.000000000 -0800' while parsing /OE/openembedded/recipes/
libxml/libxml2_2.7.2.bb
ERROR: /OE/openembedded/recipes/libxml/libxml2-native_2.7.2.bb:1:
So, it doesn't work for me.
