I have a beaglebone black rev A5A, plugged in from a USB hub (through a USB-to-power 5v cable). Everything works fine at this point, but once I plug in the USB Hub to the USB Host port on the BBB (so that I can actually use the hub as a hub), the bone resets and bootloops. When booting with the USB Hub plugged in onto the USB host port, it also bootloops.
Sometimes it does not bootloop but simply does nothing and there is no dmesg or anything. But the USB Host port becomes unresponsive, a regular USB thumb drive wouldn’t not even be recognized, unless I reboot.
The hub is a D-Link DUB-H7 High Speed USB 2.0 7-Port Hub (http://www.amazon.com/gp/product/B00008VFAF/)
Here’s some logs (through serial ftdi)
U-Boot SPL 2013.04-dirty (May 06 2013 - 16:12:47)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (May 06 2013 - 16:12:47)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
Card did not respond to voltage select!
mmc0(part 0) is current device
No micro SD card found, setting mmcdev to 1
SD/MMC found on device 1
reading uEnv.txt
14 bytes read in 3 ms (3.9 KiB/s)
4221128 bytes read in 755 ms (5.3 MiB/s)
23469 bytes read in 37 ms (619.1 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.11/beaglebone
Data Size: 4221064 Bytes = 4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f88bac
Starting kernel …
[ 0.191469] omap2_mbox_probe: platform not supported
[ 0.201943] tps65217-bl tps65217-bl: no platform data provided
[ 0.274901] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.312007] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.349115] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.386225] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.416342] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 512 MiB
0 MiB
cpsw, usb_ether
reading uEnv.txt
4221128 bytes read in 756 ms (5.3 MiB/s)
Booting from mmc …
OK
Starting kernel …
[ 0.191425] omap2_mbox_probe: platform not supported
[ 0.201892] tps65217-bl tps65217-bl: no platform data provided
[ 0.276882] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.313988] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.351097] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.388206] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.418400] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 512 MiB
0 MiB
cpsw, usb_ether
U-Boot#
U-Boot# usb tree
USB is stopped. Please issue ‘usb start’ first.
U-Boot# usb start
(Re)start USB…
USB0:
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
…etc
