Cannot enable UART's
Hi all
I cannot enable UARTS no matter what I try.
See attached for the commands I am sending, has anybody come across this problem before?
My distro information :
Linux beaglebone 4.4.30-ti-r64 #1 SMP Fri Nov 4 21:23:33 UTC 2016 armv7l GNU/Linux
I just cannot get this to work, no does editing uEnv.txt…
Please help :slight_smile:
Thanks!
So I got the bone to boot up by editing the /etc/rc.local file, which is the last script to run upon boot.
However, for some reason although I add both UART-3 and UART-5, the bone only boots with UART-5 enabled. It will boot with only UART-3 enabled if I echo that line out after the UART-5 is echoed.
So I am a step closer but not there yet
Has anybody got a solution as I cannot enable two UART's at the same time.. it's either one or the other...
Is there some pinmux issue going on?
The issue was that I was being stupid
I had a small typo in my rc.local file causing the second line initialising UART2 to be dropped
I now get this output after boot
Last login: Sat Dec 31 03:12:40 2016 from scotts-iphone
debian@beaglebone:~$ su
Password:
root@beaglebone:/home/debian# cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,BB-UART4
5: P-O-L- 1 Override Board Name,00A0,Override Manuf,BB-UART2
root@beaglebone:/home/debian# ls -l /dev/ttyO*
lrwxrwxrwx 1 root root 5 Dec 31 03:10 /dev/ttyO0 -> ttyS0
lrwxrwxrwx 1 root root 5 Dec 31 03:10 /dev/ttyO2 -> ttyS2
lrwxrwxrwx 1 root root 5 Dec 31 03:10 /dev/ttyO4 -> ttyS4
Next up is using minicom, physically connecting them together and seeing how much of a mess I can make out of that :slight_smile:
This DOESN’T WORK but as far as I got.
I thought I would super-duper UART-ize my board. Still waiting for somebody to tell me “how it is done” kinda thing.
https://groups.google.com/forum/#!category-topic/beagleboard/beaglebone-black/JvklF3O5mHs
