Cannot init new BeagleBoard-xM SGX GPU with any image?
After over two weeks of trying various images and builds on my new BeagleBoard-xM I have not been able to init the SGX GPU not matter what image I use .
Is it possible my problem is an issue with more recent CPU that reports cputype 0xE00 used in the newer BeagleBoard-xM ?
The stock microSD card image that comes with the BB-Xm does not appear to have SGX support. This puzzles me as I would think you would want to show this capability off. I feel like I am missing something obvious to all the the other experienced users.
Here is what I am seeing towards the end of the boot process:
Starting Vixie-cron.
Starting Samba: smbd nmbd.
Starting syslogd/klogd: done
Starting internet superserver: xinetd.
[ ok ]rting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Loading kernel modules for gstreamer-ti…
Running /usr/share/ti/gst/omap3530/loadmodules.shFATAL: Module cmemk not found.
FATAL: Module dsplinkk not found.
FATAL: Module lpm_omap3530 not found.
FATAL: Module sdmak not found.
done
open /dev/fb0: No such file or directory
expr: syntax error
Linux Frame Buffer Device Configuration Version 2.1 (23/06/1999)
© Copyright 1995-1999 by Geert Uytterhoeven
Usage: fbset [options] [mode]
Valid options:
No SGX hardware, not starting PɮR
Sta
__ | —’| ‘–.| .-’| | |
The Angstrom Distribution beagleboard ttyO2
beagleboard login: root
root@beagleboard:~# cputype
0xE00
I read http://processors.wiki.ti.com/index.php/SGXDbg without seeing anything that sounded similar.
I am currently NFS booting with a build I made from llinux 2.6.38.8, a xenomai 2.6.38.8 + patch, and Angstrom image Angstrom-Beagleboard-demo-image-glibc-ipk-2011.1-beagleboard.rootfs.tar.bz2
Any advice or suggestions from the anyone, especially those who have successfully used the SGX GPU is greatly appreciated.
-Ed
Newbie
BeagleBoard-xM
