Cannot install anything after failed upgrade on BeagleBone Black
Hello:
I am a newbie trying to develop a touchscreen application using a Beaglebone Black.
I was trying to install tightvncserver and first did a sudo apt-get upgrade
This took a lot of time and had some errors.
Subsequently things have gone wrong and I really cannot install anything. I have tried doing sudo apt --fix-broken install and that does not work too.
I would appreciate if anyone can give me any guidance, I am new to Linux (below please find a screen capture of my error messages).
Thank you in advance.
Edul
On your BeagleBone Black, just run:
sudo apt purge libtiopencl1
Dear R C Nelson:
Thank you for your prompt response.
I did what you suggested however I still get the same error. Here’s what I see.
Thank you
debian@beaglebone:~$ sudo apt purge libtiopencl1
[sudo] password for debian:
Reading package lists… Done
Building dependency tree
Package ‘libtiopencl1’ is not installed, so not removed
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
ti-opencl : Depends: libtiopencl1 (= 01.01.15.03-git20180817.2-0rcnee4~stretch+ 20180817) but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or speci fy a solution).
ah, it's also ti-opencl (its' for the x15, not used by the beagles..)
sudo apt purge ti-opencl
Dear Robert:
Thank you very much for your prompt responses.
The second command worked and now my system is stable and I am able to install programs.
Have a great weekend and thank you again!
Edul
