I am trying to use the Beagleboard's OTG port in host mode without
success.
What I have: board revision B5. Mini-A to Mini-B cable plugged into a
powered hub. Angstrom distribution built from sources.
if I do a cat /sys/devices/platform/musb_hdrc/mode I get b_idle
Forcing it to host via echo host> /sys/devices/platform/musb_hdrc/mode
does not do the trick...
Any suggestions? Please let me know if more information is needed.
Thanks!
I've got a B5 too and I've experienced the same problems.
I've already tried your suggestion, but:
1) when I try to run modprobe g_zero the dmseg tells me "kernel
tainted", 'cause it
doesn't find a module struct matching in the g_zero driver.
2) sys/devices/platform/musb_hdrc/mode doesn't exist, but instead I've
got a modalias file
in the same place.
I've just built a minimal-image from Angstrom, using the latest
2.6.29.r46 kernel and modules.
In addition, I'm using too a MiniA cable, which should already have
the pin4 & pin5 grounded,
forcing the BB to act as host.
Which kernel are you using please, for making the above lines work?
