Hi !
I made a card which is the exact copy of the BBB architecture (same CPU, same RAM chip, same power supply) but without HDMI and flash memory chips (to meet size requirements). With Robert Nelson’s advices, I’ve build a Debian Jessie image without board ID checking and I succeed in booting on it (thanks again Robert !)
Now I’d like to activate UART1 but I can’t. I’ve tried to install overlays with
GitHub - beagleboard/bb.org-overlays: Device Tree Overlays for bb.org boards
and put at the end of /boot/uEnv.txt
capemgr.enable_partno=BB-UART1
like I did with a real BBB but the answer of
dmesg | grep tty
is
[ 0.000000] Kernel command line: console=ttyO0,115200n8 quiet root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M quiet cape_universal=enable
[ 0.000308] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 3.842582] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 155, base_baud = 3000000) is a 8250
[ 3.843036] console [ttyS0] enabled
[ 7.687412] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.704938] systemd[1]: Created slice system-getty.slice.
Do you have any idea what’s wrong ?
