I was trying to re-flash with latest kernel, I operated as guided in
the GettingStarted-02.01.01.08.pdf. I did the re-flash several times
because it keep respond a "Kernel panic" error after reset.
But in my last trying, after I finished the *5.4.2 Running the Re-
flash Procedure*, there's no more u-boot prompt on the TeraTerm or
minicom anymore.
Before that I've re-flash the board with u-boot and uImage afforded in
*OMAP35x-PSP-SDK-02.01.01.08*, it works good except errors like
"kernel panic".
It is still able to re-flash u-boot through UART-3, but no help.
Also I failed to boot with SD. ( maybe need to set proper environment
variable first?)
This board uses Micron Memory.
Pure newbie, need help.
Xi
