I bought this product from Logic Supply that claims to work for the BBB. http://www.logicsupply.com/components/networking/wireless/uwn200/
I followed their installation instructions.
https://docs.google.com/document/d/1-CIGQYdk8ZhU3D3UCNn70jc7C9HdXvEZAsiNW71fGIE/edit
If I type in the command ifconfig ra0 I get the following…
ra0 Link encap:Ethernet HWaddr 00:0C:43:00:14:2A
inet addr:21.21.21.115 Bcast:21.21.21.255 Mask:255.255.255.0
inet6 addr: fe80::20c:43ff:fe00:142a/64 Scope:Link
RX packets:40407 errors:0 dropped:0 overruns:0 frame:0
TX packets:442 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:9262053 (8.8 MiB) TX bytes:54933 (53.6 KiB)
…Which I believe means my BBB is seeing the antenna.
However, when I look for the device from my laptop, I don’t see it on the network. Also, I can’t access the internet from the BBB unless I’m connected through usb cable or ethernet.
How do I get to use the wifi adapter? Is it possible to SSH into my BBB over wifi with PUTTY?
