Can't get SPI0 MOSI to idle low - Debian Jessie?
Not sure what I’m doing wrong here, the MOSI pin stays high after the BB-SPIDEV0-00A0.dtbo is loaded.
Have it working fine on Wheezy, but want to move to Jessie.
The .dtbo from Wheezy (BB-SPI0-01-00A0.dbto) won’t load on Jessie so I’m not able to verify that the dtbo is the issue.
Does anyone know what is going on here?
I need the MOSI pin to idle low.
-Rudy.
Not sure what I'm doing wrong here, the MOSI pin stays high after the
The .dtbo from Wheezy (BB-SPI0-01-00A0.dbto) won't load on Jessie so I'm
You may have the wrong default mode on the SPI.
Harvey
Active high, or active low( SPI default ) is something that can be changed
via an ioctl() from within code. I'm not exactly sure what's changed
between kernels 3.8.x and 4.x but there has been changes, and most
peripherals do not "beahve" as they once did. Many just use different sysfs
pathing, but others have bene changed at the driver level too it seems. SPI
I'm pretty sure is one of the later.
