Hey Guys,
I need some help in trying to configure my device tree. The goal is to make it possible to so that I can use PRUs. I keep getting stuck getting the device trees loaded. Help would be greatly appreciated. To start off here is some info about the machine:
debian@beaglebone:/lib/firmware$ uname -a
Linux beaglebone 4.4.43-ti-r84 #1 SMP Fri Jan 20 16:28:53 UTC 2017 armv7l GNU/Linux
debian@beaglebone:/lib/firmware$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.6 (jessie)
Release: 8.6
Codename: jessie
The text below shows you what happens when I try to load the UART1 device tree
This is what my slots file looks like:
debian@beaglebone:/lib/firmware$ cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,cape-universaln
I know the pruss is loaded because is see it in lsmod
debian@beaglebone:/lib/firmware$ lsmod | grep pruss
uio_pruss 5504 0
uio 10524 2 uio_pruss,uio_pdrv_genirq
Since this basic device tree is not working I don’t know what to do. I want get to eventually using PRU, but I keep getting stuck on the damn device trees. I have gone through Derek Molloy’s tutorial, I can get that to work on a different, and older beaglebone black. What I am concerned with is, I am unable to debug what is happening when the device trees stops working. I don’t want to just copy and paste because then I don’t understand what is going on. Any help will be greatly appreciated.
Ok here is a an update. I had to change uEnV.txt file in /boot and that seems to load device tree without any issues and i made changes to the following lines:
##Example v4.1.x
cape_disable=bone_capemgr.disable_partno=cape-universaln
cape_enable=bone_capemgr.enable_partno=uio_pruss_enable,PRU-GPIO-EXAMPLE
while as before those lines did not have anything to the right of the = sign and th lines were commented out.
I am now trying to use the same device tree as used by http://credentiality2.blogspot.com/2015/09/beaglebone-pru-gpio-example.html
Once I boot up with the device tree I can see the new pins that I got from the device tree:
debian@beaglebone:~$ cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,uio_pruss_enable
5: P-O-L- 1 Override Board Name,00A0,Override Manuf,PRU-GPIO-EXAMPLE
But when I go to the run the program as he instructed I run into the following error:
debian@beaglebone:~$ sudo ./pru_loader pru_egp_output.bin
prussdrv_open() failed
I don’t know what is causing that error now? Some guidance would be great (I can move this to another location if necessary)
Also I would like to know why I have to place the binary into the uEnv.txt file and just be able to change it on the fly? Is this requirement true of all linux systems?
I tried your setup, but for some reason after restarting my Ethernet stopped working, and since I wanted to clear the folder and re download the git file, I quickly found out my ethernet is not working…So I have to dig into why that is happening…I am going to try it again once I get the Ethernet working.
I don’t know why my ethernet is not working, I think it is caused by the device trees. Anyways I tried following your setup but I only see 4a300000.pruss and not the other 3. Here is what I see:
You are using a very new IOT image. I’m still using one from December 2016.
If I can get a few minutes later today, I’ll try that new image here.
I’m not sure what to suggest to try next.
Hopefully you can get your ethernet running again.
Yea I didn’t get a chance to look into why my Ethernet is failing (hoping to look into it today at night). But I really appreciate your help in all this, because I am at an impasse. If worse comes to worse I might just have to reinstall the image in order to get the Ethernet to work. I am hoping your help will provide me a better understanding of device trees and how to use PRUs. Any ways, I am using the following
settings:
debian@beaglebone:~$ uname -a
Linux beaglebone 4.4.44-bone16 #1 Sat Jan 21 10:38:02 UTC 2017 armv7l GNU/Linux
debian@beaglebone:~$ lsb_release -a
Release: 8.6
Codename: jessie
It is a beaglebone black Rev A6. I am using a 16G SD card and it is booting from SD card I believe. I am using Debian 8.6 2016-11-06 4GB SD LXQT image from the website.
Let me know if you need more info, and thank you so much again, because this is really helpful.
Ashwini Bhat
settings:
Release: 8.6
Codename: jessie
Ashwini Bhat
Damn, I am trying to recall exactly, because at that time I was trying a bunch of things.
I am looking into the history, I am retracing my steps:
I think I updated when I went into /opt/scripts/tools and use ./update_kernel.sh, but I don’t believe that updates you to the right version
I don’t believe that gets you there, I think you have to do,
I think I did ./update_kernel.sh then did ./update_kernel.sh --lts-4_4 --bone-channel, that should get you there.
Since I am being a bit vague retracing my steps and I am not 100% sure if it can get your 4.4.44-bone16, I can re-image my beaglebone black and then try to retrace my steps or I could try to replicate your setup to see if I can get that to work, since I don’t have that much data on this beaglebone black. Do remember that I have 2gb eMMC since this a older beaglebone so I have to everything off the SD card. I appreciate your help and I don’t want to waste too much of time if this ends up being an abyss of random update, and would rather use your help for something definitive that I can give clear answers too. Let me know if you are able to get to that version in a short period of time, otherwise I will first try to retrace if that doesn’t work then I will go to your version and start from there.
Thanks again,
Ashwini Bhat
I successfully update to the new kernel, it was version 45, not 44 so even a little bit newer.
After updating the DT with the pru include, I rebooted. No ethernet!
Also, I can tell from the LEDs that something is very wrong.
The heartbeat is there, but one of the other LEDs is blinking steadily and quickly.
I’ll get the USB serial and see what is going on.
Meanwhile, if you decide to re-flash the 16G card, then if you simply leave the kernel as it is we can probably make some progress easily enough.
I’m pretty sure the kernel is the same as from the IOT image, and that one I am sure works.
This is a good illustration of why I cringe when any Device Tree stuff has to be touched!
Ok, I am going to try the IOT image, this is the link: http://beagleboard.org/latest-images and I am choosing the one under alternate debian images.
debian@beaglebone:~$ uname -ar
Linux beaglebone 4.4.36-ti-r72 #1 SMP Wed Dec 7 22:29:53 UTC 2016 armv7l GNU/Linux
Release: 8.6
Codename: jessie
So should I go through your tutorial again see if it works? I have not updated the kernel (is that necessary?)
I wouldn’t update the kernel at this time. Yes, try the procedure and see what happens. I think you will be successful. If not, we can work through it.
That kernel is the TI version and it should be good to go for sure. If not, there are problems we are not going to solve without help!
It’s still not clear to me the differences between the TI and the Bone kernels. The TI kernels definitely support the latest Remoteproc.
If you don’t need GUI, stick with the IOT image. I’ve had very good luck with it.
Ok I did as your procedure says and followed chapter 9. All the outputs you were looking for in your procedure showed up. Now is there a simple program I can run to see if the PRU is working and if it is able to toggle a GPIO pin? I can just see if a pin is being toggled by putting a scope on it.
I tried going past chapter 9 into 10 but now I am getting an error with prumodin. Ideally I want to know how run a very simple pru set-up that I can debug…but going through what ti has to offer, it all done through code composer. Doesn’t seem like you used it. Either way I was trying to give yours a shot a and here is where I ended up.
root@beaglebone:/home/debian/pru-software-support-package# ls /usr/bin/ | grep pru
abspru
acpiapru
arpru
asmpru
cgpru
clistpru
clpru
dempru
dispru
embedpru
hexpru
ilkpru
libinfopru
lnkpru
nmpru
ofdpru
optpru
prumodin
prumodout
prumsg
strippru
xrefpru
root@beaglebone:/home/debian/pru-software-support-package# ls /usr/bin/ | grep prumod
prumodin
prumodout
examples labs Makefile PRU-Package-v5.0-Manifest.html
include lib pru_cape ReadMe.txt
root@beaglebone:/home/debian/pru-pid-motor/software/pru_firmware# ls
AM335x_PRU.cmd mapfile1 PRU_PID_0.c resource_table_empty.h
Makefile PRU_IO_1.c PRU_PID_0.obj result
mapfile0 PRU_IO_1.obj resource_table_1.h user_space
root@beaglebone:/home/debian/pru-pid-motor/software/pru_firmware# make clean
make: Nothing to be done for ‘clean’.
clpru -I/usr/share/ti/cgt-pru/includeSupportPackage -I/usr/share/ti/cgt-pru/include -I/usr/share/ti/cgt-pru/lib --hardware_mac=on -O2 -v3 --display_error_number --endian=little PRU_PID_0.c -z -i/usr/share/ti/cgt-pru/lib -i/usr/share/ti/cgt-pru/include -i/usr/share/ti/cgt-pru/includeSupportPackage -i/usr/share/ti/cgt-pru/includeSupportPackage/am335x --reread_libs --stack_size=0x100 --heap_size=0x100 --library=/usr/share/ti/cgt-pru/lib/rpmsg_lib.lib -m=mapfile0 ./AM335x_PRU.cmd -o ./result/am335x-pru0-fw --library=libc.a
gcc ./user_space/prumsg.c -o /usr/bin/prumsg
cd result
cp ./result/am335x-pru0-fw /lib/firmware
cp ./result/am335x-pru1-fw /lib/firmware
root@beaglebone:/home/debian/pru-pid-motor/software/pru_firmware# prumodin
/usr/bin/prumodin: line 9: echo: write error: No such device
/usr/bin/prumodin: line 10: echo: write error: No such device
I think you are making progress, but I’m having a little trouble following the grep pru.
You should end up with 2 firmwares in /lib/firmware with very specific names:
am335x-pru0-fw
am335x-pru1-fw
Just do
ls /lib/firmware
and see if they are there.
Also:
ls /dev
If you got through the example from the support package, there should be a character device file there:
rpmsg_pru30
If you get the above, that is a very good sign that everything is configured and working.
Note that you will probably have to reboot for the character device to appear after successfully compiling the firmwares and moving them /lib/firmware.
Toggling a GPIO is easy. You will need to use the __R30 special register variable.
Look in the am335x examples directory of the PRU support package:
PRU_gpioToggle
Yes you are correct I didn’t use the CCS. In the case of the PRUs, simple projects are not creating libraries of code.
And the C code files for the PRUs are no problem for the BeagleBone itself to compile.
If you have used a cross-compiler set-up before, there is a lot of configuration required, and probably debugging of problems.
I did see a note that the CCS no longer requires any sort of license. I might go back and look at it in the future,
but for now the command line via SSH is more than adequate for what I want to achieve with the PRUs.
so did an ls on /lib/firmware, I am showing part of the ls, but it should show the 2 files you are interested in (bold and underlined):
root@beaglebone:/lib/firmware# ls -l
-rw-r–r-- 1 root root 1102 Dec 9 21:09 ADAFRUIT-SPI0-00A0.dtbo
-rw-r–r-- 1 root root 1105 Dec 9 21:09 ADAFRUIT-SPI1-00A0.dtbo
-rw-r–r-- 1 root root 867 Dec 9 21:09 ADAFRUIT-UART1-00A0.dtbo
-rw-r–r-- 1 root root 867 Dec 9 21:09 ADAFRUIT-UART2-00A0.dtbo
-rw-r–r-- 1 root root 867 Dec 9 21:09 ADAFRUIT-UART4-00A0.dtbo
-rw-r–r-- 1 root root 867 Dec 9 21:09 ADAFRUIT-UART5-00A0.dtbo -rw-r–r-- 1 root root 36256 Jan 30 04:53 am335x-pru0-fw -rw-r–r-- 1 root root 96272 Jan 30 04:53 am335x-pru1-fw
-rw-r–r-- 1 root root 1205 Nov 22 15:28 am33xx_pwm-00A0.dtbo
drwxr-xr-x 2 root root 4096 Dec 9 20:49 ar3k
-rw-r–r-- 1 root root 153416 Dec 4 22:43 ar5523.bin
Although when I ls /dev I get rpmsg_pru31 not rpmsg_pru30 (again I don’t want to show everything, I am going to show the snippet that you are interested in:
root@beaglebone:/dev# ls -ltr
crw-rw---- 1 root spi 153, 1 Jan 30 04:49 spidev1.0
crw-rw---- 1 root spi 153, 3 Jan 30 04:49 spidev2.0
crw-rw---- 1 root spi 153, 2 Jan 30 04:49 spidev2.1
crw-rw---- 1 root spi 153, 0 Jan 30 04:49 spidev1.1 crw------- 1 root root 245, 0 Jan 30 04:50 rpmsg_pru31
drwxr-xr-x 2 root root 2740 Jan 30 04:50 char
prw-r----- 1 root adm 0 Jan 31 05:31 xconsole
crw-rw-rw- 1 root tty 5, 2 Jan 31 05:36 ptmx
In your pdf you look for rpmsg_pru31 instead of rpmsg_pru30, is there a reason you are looking for that one?
Even after doing that I am still getting the following error:
root@beaglebone:/home/debian/pru-pid-motor/software/pru_firmware# ls /usr/bin/prum*
/usr/bin/prumodin /usr/bin/prumodout /usr/bin/prumsg
I got through part of your tutorial and I am bit a confused. Why are you copying the .out file to a different file name and then moving it to /lib/firmware? What does that file do?
By the way, thanks again for all your help, this is really helpful.
