Can't login into my PC linux to develop my software
Dear all,
I installed the kernal projekt for the BBB boar at my PC in the virtual Linux. The build of the kernal was canceled because the virtual Memory of 20GB was too small. After log out of the Linux, I stards the Oracle and the Linux again. But After send Password I see the Login window again. But I know that the build of the kernal fills the whole virtual disk.
What can I do that I can start the Linux Login successfull? The Password is ok.
please help me and send me a response.
Best regards Edgar.
It seems that you have a Windows box with a Linux VM. I think what happened
is that you filled out the disk image you created too small (not the
virtual memory, which is a different thing). While there are ways to fix
that, I think you should start from scratch, delete the existing Linux VM
and create a new one giving it a larger disk.
Hallo Mr. Klosowski,
thanks for your Response. I will do it.
