Can't make work image from Narcissus
      I've downloaded a kernel image and file system from Narcissus
and flashed onto SD card but unfortunately I can't make it work. I get
the following error from U-boot:
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.01 (May 17 2009 - 16:46:04)
I2C: ready
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
MUSB: using high speed
mtdparts variable not set, see 'help mtdparts'
In: serial usbtty
Out: serial usbtty
Err: serial usbtty
Board revision C
Serial #0e6e0003000000000403230911024015
reading uImage
** Unable to read "uImage" from mmc 0:1 **
Wrong Image Format for bootm command
ERROR: can't get kernel image!
OMAP3 beagleboard.org #
                   I tried changing the U-boot command from "mmcinit"
to "mmc init" as suggested in the wiki but it doesn't work for me,
also I've seen the message related to the "mtdparts" variable
uninitialization.
                   Do I need any special configuration to load this
image?. Should I use other files in my FAT32 partition apart from the
files MLO, u-boot.bin and uImage.bin?. Is there something wrong with
my U-boot environment?
                   I will appreciate your help!
Alex.
Can you paste the output of "printenv" command at u-boot console.
I think the filename should be uImage.bin rather than uImage in the
MMC filesystem.
-D
Hi Deepak Narayan,
Thanks for the advise, I changed the bootcmd variable on U-boot to load uImage as uImage.bin and the board is booting now.
Alex.
