I tried to do a mount -t cifs and got an error stating cifs filesystem was unknown.
So I tried opkg install cifs, opkg install cifs-utils, and opkg install smbfs.
All failed stating “unknown package”.
Is it possible somehow to mount Windows shares on the BBB?
Bill
Did you try installing http://www.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a/base/cifs_3.5.6-r1_armv7a.ipk
When I have problems finding the package I am sure should exist, I go to http://www.angstrom-distribution.org/repo/?pkgname=cifs and search for what I think I need. The last I was searching for was lrzsz, I use zmodem transfers quite a lot, but understand not having it in the default install.
I didn’t try that because I didn’t know about that Feeds website.
I have now pulled that down and installed it, rebooted, tried my mount again and now get a different error.
mount error: cifs filesystem not supported by the system
mount error(19): No such device
I see that’s a very popular error msg on Google.
modprobe cifs says: Module cifs not found.
Do I need to install one of the kernel-module-cifs packages on the Feeds website also?
I assume that it needs a kernel package, but I didn’t try to figure it out myself. Did you get the solution working?
I didn’t know what was needed and didn’t want to blow up the image (since I have other stuff ported to the BBB and
not backed up anyplace yet).
Basically I got disgusted and just gave up.
Bill
I just figured out that the kernel wasn’t even built with CIFS support as a module, so I don’t think I can mount a share from windows without rebuilding the kernel.
I figured this out by looking at the current kernel running configuration with this command and it’s result.
root@beaglebone:~# zcat /proc/config.gz | grep -i CIFS
CONFIG_CIFS is not set
I’m attempting to build a new kernel with the 3.11-rc right now, just to see if perhaps my USB crash problems go away with the latest kernel, so I’ll probably include CIFS support in my kernel.
Wim.
When I click on the link http://www.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv7a/base/cifs_3.5.6-r1_armv7a.ipk I get “Page not found”.
Has anybody found a solution to mount a cifs share on BBB?
is there any way to mount windows share on angstrom?
