Hi All,
I am having some problems running bonescript without cloud IDE 9. The weird thing is when I run the javascript file that requires bonescript while SSH’d as root it works perfectly, the problem is when I VNC into the beaglebone and try to run the exact same script.
Here is some information that may help:
OS: Debian 7.8 (Wheezy)
Board version: Beaglebone black rev. B6 (as printed on the underside of the board)
Kernel: 3.8.13-bone50
When I try to run the javascript file that requires bonescript while VNC’d I get the following output:
module.js:340
throw err;
Error: Cannot find module ‘bonescript’
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. (/home/debian/testBBB.js:1:71)
at Module._compile (module.js:456:26)
at Object.Module._extensions…js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
I am trying to run bonescript without using cloudIDE9 since I do not have internet connectivity where the BBB will be installed.
I really appreciate any help. Please let me know if something I said above is unclear.
-Gabe
