Should use external power supply and not rely on PC USB power which is limited for flashing eMMC.
Step 1: Use exiting Beaglebone Black to create a flasher image on your microSD card.
There is a file on most newer Beaglebone Blacks that can make a flasher image on a microSD card.
from ssh terminal window, change your directory and run the script if it is on your OS distribution.
THIS WILL OVER WRITE YOUR microSD card and take some time till completed.
cd /opt/scripts/tools/eMMC
./beaglebone-black-make-microSD-flasher-from-eMMC.sh
when process is done, you need to power down Beaglebone Black and remove your microSD card.
Step 2: Use created microSD flasher card to clone your Beaglebone Black on other BBB’s or Restore yours.
You can use this microSD card to put in another Beaglebone Black with Power off, press S2 and hold
while powering up. It will put this image in your Beaglebone Black eMMC and over-write what was there.
Step 3: Storing your microSD image on your Ubuntu Linux computer.
Caution: when you put a bootable microSD card in your computer, you may need to “Cancel” pop up window from trying to run this.
change directory on your Ubuntu Linux PC to where you want this backup image to go
the name for you file can be anything but should be descriptive, eMMC_Backup_name-sdcardsize.img.gz
This next command will take the microSD card and create an image file that will be stored on your linux pc computer.
make sure your microSD device is correct, ie - /dev/mmcblk0
( you can find this with the Ubuntu Linux “Disks” package under the SD card ICON in the upper right.)
This takes the SD card and creates a compressed image in the current linux pc directory. Note -4gb is a 4gb microSD card size.
$ sudo dd if=/dev/mmcblk0 | gzip > BBB-eMMC-flasher-debian-date-xxxx-4gb.img.gz
it never hurts to run $ md5sum file.img.gz to get a check sum type value and record it in an accompaning text file for
verifying the file does not become corrupted.
Step 4: Using a compressed image to create a bootable master microSD flasher card.
This process will uncompress your .gz file, you may what to create a backup .gz file and copy it somewhere else first.
Unzip compressed file:
$ sudo gunzip BBB-eMMC-flasher-debian-date-xxxx-4gb.img.gz
this converted the file to an .img file BBB-eMMC-flasher-debian-date-xxxx-4gb.img
Now use the .img file to create a flasher microSD card
Note: make sure your SD card on your linux pc is /dev/mmcblk0 ( some pc use sda, etc.)
$ sudo dd if=BBB-eMMC-flasher-debian-date-xxxx-4gb.img of=/dev/mmcblk0 bs=8M
takes about 10 minutes to finish.
You can remove this card and put it in a Beaglebone Black, hold S2 down, power up, then
release S2 after about 5 to 10 seconds, then wait about 10 minutes for image to be written to eMMC.
You may want to delete the .img file on your Linux PC and just keep the .img.gz compressed file to conserve disk space.
DONE.
