i have been using minicom in my beaglebone to capture serial data from a GPS. what can i do to continue to capture serial data at the background after disconnecting the USB-lan cable ? I want the process to continue even after removing the USB cable?
minicom -C capturefile.log (this works only when the USB cable is connected to the linux PC) Please help! Thanks in advance.
What you need is an application that runs natively on the Beagle.
Perhaps a Python script or some such thing.
You start the native app and then off you go …
It should also be possible to start the app after a UBoot
I am using minicom on beaglebone.
My linux pc monitors the GPS receiver-beaglebone serial transmission via minicom running on PC too. But i would like to disconnect beagle from PC so Beagle’s minicom is still running in the background… please let me know if i can do this using stty. Cat function doesnt work in my case as the process loses some GPS data.
check out “screen”. you can run minicom in a screen session or use screen in place of minicom, it will keep running when you disconnect and you can reatach to it later.
yes i was just using console on PC with minicom talking to the bone and running another minicom session in the bone which is capturing GPS data. so when i unplug my RJ45 and usb-serial from bone -to PC. the bone’s minicom session automatically cuts its serial data from GPS. i will use serial and see if i can this straight.
