case to hold beagleboard?
Hi!
I am looking for a small case that will help me hold the beagleboard and have some space to stuff in a usb hub (4 or 7 port). The aim is to create something similar to www.fit-pc.com based on beagleboard :slight_smile: with just one wire coming out (one that powers the usb hub).
The acrylic case shown here: http://specialcomp.com/beagleboard/ seems to just fit the board without any additional space (and holes) for adding a usb hub.
Has anyone built a tiny PC with a tiny case :slight_smile: using beagleboard? If yes, Iā€™d like to know what kind of case was used and maybe a pointer to the place where I can get one.
I tried searching for pico-itx cases, but there aint many out there.
Thanks in advance,
S.
For a unique, retro look an old candy box work great:
http://www.flickr.com/photos/jadon/2750698127/
Metal conducts heat better than acrylic.
The green board is a DC-DC switching power supply.
Christmas is a good time to find boxes like this.
IMG_0712.CR2 | Jason Kridner | Flickr
Very neat indeed :slight_smile:
Any recommendation on a usb hub (externally powered one)? 4 or 7 port
would be good. My plan is to buy this (cheap?) 7-port hub:
  http://www.supermediastore.com/usb-2-hub7-port-for-pc-mac-with-ac-adapter.html
and rip out the outer plastic casing and stuff the board+connectors in
my would-be (beaglepc :slight_smile: case. is there a better way to do this? can
one get the hub pcb (with connectors etc) in barebones style?
Thanks!
S.
Supermediastore also has a 3-port + Ethernet hub that I am using and
it works great. Plus, if you use one port with the SparkFun cable to
power the Beagleboard, you can run everything off of a single power
supply. Of course you can also just splice two power connectors onto
one power supply (I've done this too). Take a look at the shopping
list for more ideas: http://code.google.com/p/beagleboard/wiki/BeagleBoardShoppingList
Best regards,
Geof
