Change I2C2 Pins to P9_21 and P9_22 fails
I have an extention board where I use d_can0 and d_can1.
To free Pin P9_19 and P9_20 for d_can0, I switched I2C-2 to P9_21 and P9_22 in mode 2
On these I2C-2 pins I have connected a RTC DS1307
My device overlay worked fine with Debian 9 and Kernel 4_14
Now I want to update to the current Debian11 image.
I will try to give a clear summary of what I tried yet
This is the overlay that I want to use
BB-I2C2-ALTERNATIVE-RTC-DS1307.dts (2,3 KB)
When I am only using this overlay, probe of rtc-ds1307 in overlay fails and I2C controller seems to be “blocked”.
[    5.001137] omap_i2c 4819c000.i2c: controller timed out
[    5.006636] rtc-ds1307: probe of 2-0068 failed with error -110
[    6.057122] omap_i2c 4819c000.i2c: controller timed out
[    7.113107] omap_i2c 4819c000.i2c: controller timed out
[    8.169124] omap_i2c 4819c000.i2c: controller timed out
[    9.225105] omap_i2c 4819c000.i2c: controller timed out
[   10.281125] omap_i2c 4819c000.i2c: controller timed out
[   11.337115] omap_i2c 4819c000.i2c: controller timed out
[   12.393125] omap_i2c 4819c000.i2c: controller timed out
[   13.449110] omap_i2c 4819c000.i2c: controller timed out
[   13.467247] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
Also i2cdetect -r 2 is not able to find anything, it is only showing -- --… for all address
When I combine this overlay with the BB-CAN0-00A0.dtbo, than it still can not probe in boot sequence but i2cdetect -r 2 is now able to detect the 68 which is the address of the ds1307.
The OF_FULLNAME looks different compared to old linux.
With Kernel 5.10:
OF_NAME=ds1307
OF_FULLNAME=/ocp/interconnect@48000000/segment@100000/target-module@9c000/i2c@0/ds1307@68
With Kernel 4.14:
OF_FULLNAME=/ocp/i2c@4819c000/ds1307@68
When I run this on a standalone beaglebone black, than I can not see the “controller timed out” messages with dmesg but as soon as I boot with connect extention board, these messages are there.
When I remove the ds1307 lines from the overlay (lines 67 and 100-102), than I am able to manually probe the ds1307
root@BeagleBone:/sys/class/i2c-dev/i2c-2/device# echo ds1307 0x68 > /sys/class/i2c-dev/i2c-2/device/new_device
root@BeagleBone:/sys/class/i2c-dev/i2c-2/device# dmesg | grep i2c
[    7.840438] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[    8.887850] i2c /dev entries driver
[    9.114806] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    9.117005] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[   10.154779] omap_i2c 4819c000.i2c: controller timed out
[   11.210751] omap_i2c 4819c000.i2c: controller timed out
[   12.266800] omap_i2c 4819c000.i2c: controller timed out
[   13.322743] omap_i2c 4819c000.i2c: controller timed out
[   14.378760] omap_i2c 4819c000.i2c: controller timed out
[   15.434750] omap_i2c 4819c000.i2c: controller timed out
[   16.490761] omap_i2c 4819c000.i2c: controller timed out
[   17.546750] omap_i2c 4819c000.i2c: controller timed out
[   17.564879] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[  371.212227] i2c i2c-2: new_device: Instantiated device ds1307 at 0x68
Does anyone have an idea on how to solve it?
  • Where is i2c2 initialized first? Is it possible to initialize it directly to P9_21 and P9_22?
  • Why does reconfiguring take approx. 7sec?
  • Why does reconfiguring seems to depend on initialyzing P9_19 and P9_20 to d_can0_rx/tx?
  • Why there is a dependency whether the pins are free or the can transceiver and the ds1307 are connected?
  • Is it possible to remove existing i2c2 before making the new device on the alternative pins?
  • Is it possible to delay probing of ds1307 in overlay? 10sec additional time before ds1307 works does not matter for me
Many thanks
Martin
Hi @Martin_Voelz that should work, can you please share your full serial boot log… (including u-boot)…
Both those set of pins share i2c2, moving P9_19/P9_20 is needed as by default it’s i2c, so it would short between P9_21/P9_22 and make i2c transactions interesting…
Answer part4
And my last test was to set P9_19/P9_20 to gpio in can0 pingroup, than P9_21/P9_22 to i2c2 and as a last step P9_19/P9_20 to can0 mode.
But this overlay did not compile with error “dublicat node name”:
BB-FLASHBOX-CAPE-00A0_dublicateNodeName.dts (6,9 KB)
Do you have any suggestions how to solve this?
Thanks Martin
Answer part3
To solve this I tried is to put all the settings into one overlay file and put the can0 settings before the i2c2 settings. Unfortunatly this did not work. Controller timed out again:
BB-FLASHBOX-CAPE-00A0.dts (6,6 KB)
bootlog_completeOverlayInOneFile.txt (4,9 KB)
Answer part2
Next thing I tried was to set P9_19/P9_20 to GPIO mode before setting P9_21/P9_22 to i2c2.
Without much thinking, I did this inside the i2c2-pingroup and now i2c2 init works.
root@BeagleBone:~# dmesg | grep ds1307
[    4.003779] rtc-ds1307 2-0068: registered as rtc1
root@BeagleBone:~# cd /dev
root@BeagleBone:/dev# ls rt*
rtc  rtc0  rtc1
Unfortunatly, now CAN0 can not get the pins, because they are in i2c2 pingroup.
[   29.543473] pinctrl-single 44e10800.pinmux: pin PIN95 already requested by 4819c000.i2c; cannot claim for 481cc000.can
[   29.776049] pinctrl-single 44e10800.pinmux: pin-95 (481cc000.can) status -22
[   29.869397] pinctrl-single 44e10800.pinmux: could not request pin 95 (PIN95) from group pinmux_dcan0_pins  on device pinctrl-single
[   29.992577] c_can_platform 481cc000.can: Error applying setting, reverse things back
BB-I2C2-ALTERNATIVE-RTC-DS1307.dts (2,6 KB)
bootlog_modified_i2c2_pinmux.txt (5,1 KB)
Hi @RobertCNelson,
thank you very much for this impulse for brainstorming. Thinking of the pins as physical connections makes it indeed much clearer.
I did some further tests with interesting results:
This is the bootlog from a standalone beaglebone black (can not check DS1307 because not connected):
bootlog_standalone_beagleboneblack.txt (4,3 KB)
This is the bootlog from beaglebone black and Cape PCB, DS1307 not working, Controller timed out:
bootlog_beagleboneblack_withCape.txt (5,2 KB)
I have to split my answer here, because as a new user I am only allowed to add two links.
From all my test, this is my current overview of the problem:
When I have the Pins P9_19 and P9_20 in the bb_i2c2_pins group, than CAN driver shows error at approx. 30 seconds after starting kernel. (This might happen, when I do not enable the BB-I2C2-ALTERNATIVE-RTC-DS1307.dts overlay for example)
When I assume, that CAN driver always needs so long to initialize the pins, than for the first 30sec, the I2C2 is connected to 4 pins at the same time. (Connected to DS1307 and CAN Transceiver) which might lead to not beeing able to communicate to the DS1307.
The i2c driver seems to make retrys, but the rtc-ds1307 driver seems to try only once.
What I would need is a possibiliy to not only remove the P9_19 / P9_20 from the bb_i2c2_pins group (there they are by default), but also to change the mode of these pins already in the BB-I2C2-ALTERNATIVE-RTC-DS1307.dts overlay. (Not having to rely on CAN driver changing the mode of them)
I did some tests with the 4_14 kernel.
1.) when I only load the overlay for the alternative I2C2 pins and not the CAN0 overlay, than I have the same issue that “Controller timed out”
2.) When I do not load any overlay, I see a difference.
The 4_14 image does not have a i2c2 pingroup after boot. The pins P9_19 and P9_20 seem to be single pinmux pins.
The 5_10 image has an i2c2 pingroup with P9_19 and P9_20
Next thing I will try: Remove the settings for i2c2 in the am335x-bone-common.dtsi and recompile the am335x_boneblack_uboot.dts the because for my special usecase I do not need the CAPE eeproms.
I tried changing the am335x-bone-common.dtsi in a way that it does not create a pingroup for i2c2 but this did not have success. Still “Controller times out” when probing the DS1307.
When comparing the files /sys/kernel/debug/pinctrl/44e10800.pinmux-pinctrl-single/pingroups in both systems, I recognized:
In the Linux 4.14 file, CAN0 and CAN1 are the first devices in this file.
In the Linux 5.10 file, CAN0 and CAN1 are the last devices in this file.
