Changing display resolutions...
How do you change the display resolution (of the eventual device, e.g
DVI) in real-time in Linux? Do you change the timings field found at /
sys/devices/platform/omapdss/displayx/timings?
Jerry
Hi Jerry!
I need to do the same, and I dont have the device access over the sysfs due to an kernel without dss2. But I read that with an kernel >=2.6.29 the dss2 is included and resolutions can be changed in realtime by choosing a different display mode in the sysfs structure (dss2 documentation: http://groups.google.com/group/beagleboard/browse_thread/thread/115867f718b52e4b/4c64b2c614622053).
I also tried to change the resolution over the framebuffer driver (struct fb_var_screeninfo in linux/fb.h). But the pixelclock and the other timings did not change.
Sebastian
I have pseudo managed to get it working before, by echo'ing to the
timings node.
My steps are now as follows:
a) disable display
b) disable manager
b) echo new timings to the displayx/timings
c) fbset appropriately
d) enable manager
e) enable display
This seems to be working reliably for me now - previously, i had
omitted the fbset operation and was getting GFX_FIFO_UNDERFLOW errors
from the driver. This would happen randomly.
Jerry
