How we can select the ChipSelect on spi1 (dev/spidev2.0)? by default the SPI1_CS0 is used and I would like use one or the either two connects two spi-modules…
regards,
Mathieu
regards,
Mathieu
The second number in the spidev2.0 tells you which chip select that device node is for, in this case (as you correctly mentioned) chip select 0. To enable chip select 1 you must modify the board file to add chip select 1 in addition to chip select 0 through spidev.
e.g.in the kernel board file
static struct spi_board_info bone_spi0_info[] = {
.modalias = "spidev",
.max_speed_hz = 48000000, //48 Mbps
.bus_num = 1,
.chip_select = 0,<---- this would be 1
.mode = SPI_MODE_1,
This is from memory so somebody please correct me if it's a touch wrong!
