dongle works fine on BeagleBoard/Angstrom.
Can someone please confirm that these dongles can be used with
BeagleBoard revision-B boards?
Plus I’m also looking to add an LCD panel on the same BeagleBoard, which
according to some posts can be achieved adding LCD to SPI interface.
I want to know if anyone has tried adding LCD panel to BeagleBoard and
if its working fine without any major issues.
Plus I'm also looking to add an LCD panel on the same BeagleBoard, which
I think the post you refer to was made by me. What I wrote was that there is
basically two different ways to add a LCD display.
1) Using the "official" parallel display interface and a parallel display
2) Using one of the SPI interfaces utilizes a SPI serial display
What you need pretty much depend on your use case. I.e.
1) Do you want to add a text-based or a graphical display?
2) Monochrome or Color
3) Low- or High-resolution
4) High- or Low-frame update rate?
These questions might help you indicating if you should go for a parallel or
a SPI display.
I have had many different displays of both kinds (10+) connected to OMAPs
(though not on Beagle yet) and found no real problems. Only stuff which you
might need to work your way through
