Hi All,
Are there any way to clone an SD card with a working Ubuntu 12.04 for BeagleBoard xm? I’d like to have a backup by cloning, so the cloned SD can be bootable and works just like the original.
Thanks in advance.
Hi All,
Thanks in advance.
On the xM:
sudo dd if=/dev/mmcbkl0 of=(second card)
Thank you for the quick reply, does that mean I can clone the SD card on the xm itself while it is running? I thought I have to power it off, pull the card out, and do it on something like a PC ubuntu or vm…
So I have to get a SD card adapter and for the “of” part, is that correct? Thanks in advance.
RobertCNelson於 2014年2月15日星期六UTC+8上午12時36分13秒寫道:
Either or "should" work.. just as long as you do not use any uuid values in
u-boot or /etc/fstab..
Nice tool: PV!
pv /dev/sdb | dd of=<sd_image_file>
Then, you will see the progress!
Cheers.
W dniu piątek, 14 lutego 2014 18:18:02 UTC+1 użytkownik RobertCNelson napisał:
