I am having some problems understanding exactly what happens when I place a program in the autorun directory under Cloud9. I have put several simple programs in there and they all run fine on startup. However . . .
I have a JavaScript web server and an HTML file in a directory under Cloud9. Everything works perfectly with them when I run the JavaScript file from Cloud9. But I want it to autorun on startup. When I place a copy of the JavaScript file in the autorun directory, it does start on startup. However, I get an error saying it can’t open the HTML file.
I thought, OK, it needs the path to the HTML file from its new location in the autorun directory, but that didn’t. I thought maybe the system treats programs in the autorun directory as though they are in the cloud9 root directory. That path doesn’t work either. I even tried putting a copy of the HTML file in the startup directory with the JavaScript file. It still says it can’t open the HTML file. I have tried leaving the JavaScipt file in its original location, and putting a link file in the autorun directory. I still get the same can’t open the HTML file.
I have tried every path I could think of, and I still can’t get it to open up the HTML file when trying run it from the autorun directory. There is obviously something going on here that I don’t understand!
