Cloud 9 inaccessible on BBB
I get this via Gate One when I try to start Cloud 9 - I’m not sure I’m invoking it the way I should be, and from what I can tell there’s already a node process running when I try ps -A. But for some reason C9 is still 404-ing. :frowning:
root@beaglebone:/usr/share/cloud9# node bin/cloud9.js
Error: require.paths is removed. Use node_modules folders, or the NODE_PATH environment variable instead.
at Function.Module._compile.Object.defineProperty.get (module.js:386:11)
at Object. (/usr/share/cloud9/support/paths.js:7:8)
at Module._compile (module.js:449:26)
at Object.Module._extensions…js (module.js:467:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.require (module.js:362:17)
at require (module.js:378:17)
at Object. (/usr/share/cloud9/bin/cloud9.js:6:1)
