Was working in a Beagle Bone Blue workshop trying to do some apt installs. Hosted WiFi off of PC as a pass through to bridge Blue to network.
Commands run
sudo apt update
sudo apt install -y lsb-release
While commands were running in terminal, copied and pasted a python 3 file into an existing .py file. Cloud 9 crashed for a few min before restarting. Python file did not save. Tried to paste again cause a Cloud 9 disconnect for a few seconds before it recovered.
Was told to report some of the journalctl.
Jul 11 15:03:45 beaglebone dnsmasq-dhcp[4267]: DHCPREQUEST(usb0) 192.168.7.1 50:65:83:68:c0:48
Jul 11 15:03:45 beaglebone dnsmasq-dhcp[4267]: DHCPACK(usb0) 192.168.7.1 50:65:83:68:c0:48 Austin-PC
Jul 11 15:04:38 beaglebone wpa_supplicant[417]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-50 noise=9999 txrate=52000
Jul 11 15:04:41 beaglebone dnsmasq-dhcp[4267]: DHCPREQUEST(usb0) 192.168.7.1 50:65:83:68:c0:48
Jul 11 15:04:41 beaglebone dnsmasq-dhcp[4267]: DHCPACK(usb0) 192.168.7.1 50:65:83:68:c0:48 Austin-PC
Jul 11 15:05:36 beaglebone dnsmasq-dhcp[4267]: DHCPREQUEST(usb0) 192.168.7.1 50:65:83:68:c0:48
Jul 11 15:05:36 beaglebone dnsmasq-dhcp[4267]: DHCPACK(usb0) 192.168.7.1 50:65:83:68:c0:48 Austin-PC
Jul 11 15:06:32 beaglebone dnsmasq-dhcp[4267]: DHCPREQUEST(usb0) 192.168.7.1 50:65:83:68:c0:48
Jul 11 15:06:32 beaglebone dnsmasq-dhcp[4267]: DHCPACK(usb0) 192.168.7.1 50:65:83:68:c0:48 Austin-PC
Jul 11 15:06:52 beaglebone cloud9ide[4307]: cache /opt/cloud9/build/standalonebuild/build/standalone/modules/ace/mode/python.js
Jul 11 15:06:52 beaglebone cloud9ide[4307]: cache hit /opt/cloud9/build/standalonebuild/build/standalone/modules/ace/mode/python.js
Jul 11 15:06:52 beaglebone cloud9ide[4307]: cache /opt/cloud9/build/standalonebuild/build/standalone/modules/ace/snippets/text.js
Jul 11 15:06:52 beaglebone cloud9ide[4307]: cache hit /opt/cloud9/build/standalonebuild/build/standalone/modules/ace/snippets/text.js
Jul 11 15:06:53 beaglebone cloud9ide[4307]: cache /opt/cloud9/build/standalonebuild/build/standalone/modules/ace/snippets/python.js
Jul 11 15:06:53 beaglebone cloud9ide[4307]: cache hit /opt/cloud9/build/standalonebuild/build/standalone/modules/ace/snippets/python.js
Jul 11 15:06:53 beaglebone cloud9ide[4307]: VFS Exception in function ‘readfile’:
Jul 11 15:06:53 beaglebone cloud9ide[4307]: TypeError [ERR_INVALID_CALLBACK]: Callback must be a function
Jul 11 15:06:53 beaglebone cloud9ide[4307]: at makeCallback (fs.js:137:11)
Jul 11 15:06:53 beaglebone cloud9ide[4307]: at Object.close (fs.js:395:20)
Jul 11 15:06:53 beaglebone cloud9ide[4307]: at /opt/cloud9/build/standalonebuild/node_modules/vfs-local/localfs.js:543:20
Jul 11 15:06:53 beaglebone cloud9ide[4307]: at /opt/cloud9/build/standalonebuild/node_modules/vfs-local/localfs.js:365:21
Jul 11 15:06:53 beaglebone cloud9ide[4307]: at FSReqWrap.oncomplete (fs.js:155:5)
Jul 11 15:06:53 beaglebone cloud9ide[4307]: Scheduling process exit
Jul 11 15:06:55 beaglebone cloud9ide[4307]: Exiting after uncaught exception in ‘readfile’:
Jul 11 15:06:55 beaglebone cloud9ide[4307]: TypeError [ERR_INVALID_CALLBACK]: Callback must be a function
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at makeCallback (fs.js:137:11)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at Object.close (fs.js:395:20)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at /opt/cloud9/build/standalonebuild/node_modules/vfs-local/localfs.js:543:20
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at /opt/cloud9/build/standalonebuild/node_modules/vfs-local/localfs.js:365:21
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at FSReqWrap.oncomplete (fs.js:155:5)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: Error: EDISCONNECT: Agent disconnected
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at Parent.Agent.disconnect (/opt/cloud9/build/standalonebuild/node_modules/smith/smith.js:414:16)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at Parent.disconnect (/opt/cloud9/build/standalonebuild/node_modules/vfs-child/parent.js:64:39)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at Transport.emit (events.js:189:13)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at Socket.onDisconnect (/opt/cloud9/build/standalonebuild/node_modules/smith/smith.js:126:14)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at Socket.emit (events.js:194:15)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at endReadableNT (_stream_readable.js:1103:12)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: at process._tickCallback (internal/process/next_tick.js:63:19)
Jul 11 15:06:55 beaglebone cloud9ide[4307]: destroying because of error undefined
Jul 11 15:07:14 beaglebone cloud9ide[4307]: User saving /BeagleBone/tamulinkcon.py
Jul 11 15:07:14 beaglebone cloud9ide[4307]: Successfully saved /BeagleBone/tamulinkcon.py
