I just recently got the BeagleBone Black, and I wanted to learn more about it so I plugged it into the computer with the provided cable. At first, it worked quite nicely, and I could easily access 192.168.7.2 and 192.168.7.2:3000. I went through the tutorial from the BeagleBoard for the Cloud9IDE, and it all seemed to work nicely. I wanted to get back to the starting page, so I (very stupidly) unplugged the BeagleBoard without powering it down, and then plugged it back in. Still worked. Problem now is that when I tried accessing the sample programs that I saw on the first run (blinkled.js, among others), they had disappeard. So, I figured maybe I plugged it in wrong (I’m a newbie…sorry for my ignorance) and did the same thing again. This time, still worked, but same thing. So I figured unplugging it again wouldn’t work, so this time I just messed around with it and made the sample program myself (I am using “Bad to the Bone” beaglebone guide as my reference). However, now I was unable to save the program (it just wouldn’t let me). At this point, I was rather upset, and so I unplugged it again to just put it to the side for a while. I tried it again not too long after, and the Cloud9 IDE wouldn’t even start. the 192.168.7.2 does open up, but when I try to access 192.168.7.2:3000, it gives me
Unable to connect
Firefox can’t establish a connection to the server at 192.168.7.2:3000.
The site could be temporarily unavailable or too busy. Try again in a few
moments.
If you are unable to load any pages, check your computer’s network
connection.
If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
I have played around with it for a while now, reloading the page multiple times, pressing the reset button (although I don’t know what the other two buttons are for)…it still won’t work.
The only other thing that I noticed was that it seems to get warm when plugged in. I don’t know if that is normal, but I figured I’d mention it.
how would i do that from a mac system, that terminal program doesn’t have mac systems under it’s compatibility. also is this a problem that i will keep having? i don’t feel like that fix is really explaining the problem very well, like why, or how to avoid it from happening again.
a new window will appear and ask you " Are you sure you want to continue connecting (yes/no)? " type " yes " and press enter
next you will be asked for a password " root@192.168.7.2’s password: " leave blank and press enter.
your next prompt will be " root@beaglebone:~# " type " mkdir /var/lib/cloud9 " and press enter
eject your beaglebone and reset the power. after booting back up you should be back in buisness.
now for the explanation. after going threw the automated walk threw in cloud9 it erases the folder " /var/lib/cloud9 " but this is an important folder that you need in order to use cloud9. so what your doing is using terminal to make an ssh connection to the beaglebone(1-6). this is basically a way to use the command line on the beaglebones terminal(like dos on a windows machine) from a remote computer.
then you create a new folder in place of the one that was deleted(7). mkdir = make directory
after that you just have to restart your beaglebone and it’s like it was never gone. i hope this helps everyone else. this stressed me out for the last two days.
Yes. I have a linux machine as well, and they seem to be having the same problems. I even tried just manually adding the /var/lib/cloud9 folders into the beaglebone, ejected, reset, and attempted it again (from my Mac) but had the same issue. Trying to use GateOne (from any machine) gives me the same error.
