I installed the latest Debian build (including Cloud9) on a BeagleBone Blue, then I downloaded the Strawson Robotics Cape software and the rcpy Python library. That all works fine, except for one problem: the robotics cape software requires to be run from the root user, while Cloud9 is configured to run from debian.
In order to run a Python script, I currently need to use a Cloud9 terminal window and switch to root. The regular Cloud9 run facilities fail, with a message says that root access is required.
Is there a way to either (a) set up Cloud9 run configurations to run as root, (b) configure the Cloud9 service to run from the root account, or © something else, that would allow me to run directly, using the run button?
(thanks)
– Michael
Hi Michael,
to run from debian.
root, (b) configure the Cloud9 service to run from the root account, or (c)
This was a security change in cloud9, it can be undone via:
edititing:
/lib/systemd/system/cloud9.service
remove: (debian user)
"User=1000"
and reboot, it should load up as root..
works! And I would never have found that on my own. Thanks.
