I have found that after installing a freshly built image of cloud9. Some services (for example avahi, and cron) do not run until after the first reboot. Could someone explain the philosophy behind this, or point me to the code (service?) that runs the first time to enable a service, but not start it? For example, after the initial boot:
root@beaglebone:~# systemctl status avahi-daemon.service
avahi-daemon.service - Avahi mDNS/DNS-SD Stack
Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled)
Active: inactive (dead)
CGroup: name=systemd:/system/avahi-daemon.service
But on the second boot:
Active: active (running) since Sat, 01 Jan 2000 00:07:33 +0000; 12s ago
Main PID: 86 (avahi-daemon)
Status: “avahi-daemon 0.6.31 starting up.”
├ 86 avahi-daemon: running [beaglebone.local]
└ 109 avahi-daemon: chroot helper
Jan 01 00:07:32 beaglebone avahi-daemon[86]: avahi-daemon 0.6.31 starting up.
Jan 01 00:07:33 beaglebone avahi-daemon[86]: Successfully called chroot().
Jan 01 00:07:33 beaglebone avahi-daemon[86]: Successfully dropped remaining …
Jan 01 00:07:33 beaglebone avahi-daemon[86]: Loading service file /services/…
Jan 01 00:07:33 beaglebone avahi-daemon[86]: Network interface enumeration c…
Jan 01 00:07:33 beaglebone avahi-daemon[86]: Registering HINFO record with v…
Jan 01 00:07:33 beaglebone avahi-daemon[86]: Server startup complete. Host n…
Jan 01 00:07:33 beaglebone avahi-daemon[86]: Service “beaglebone” (/services…
