I’m sure I’m doing something stupid but I can’t seem to install (run?) an application. I’m running Debian on a BBB and connecting through putty. It’s a remote USB system from Eltima. These are the instructions I got:
- Please try this build:
It is compatible with all ARM platforms.
Unpack the archive to the root directory and execute postinst script
from /opt/Eltima/eveusb/bin/ Sub-folders will be determined by the
archive automatically.
I also asked this and got a response:
OK I have a Beaglebone black (4GB Debian) attached to my PC and I’ve
unpacked eveusb_3.6.0.armv5te.tgz to root.
I’m looking at the /opt/Eltima/eveusb/bin/ directoy and there are two
files “eveusbc” and eveusbd".
Which one do I need to call?
Will it be installed permanently or will I need to call it each time
we re-boot?
Response:
USB Network Gate is designed to run as a system daemon. This ensures that all USB ports are re-shared and connections re-established automatically on system boot (before user login).
eveusbd is the UNG daemon (starts with the system and is constantly running in the background), eveusbc is a command-line utility for controlling it. So you are probably looking for the latter.
I did the unpacking OK and there are two files in the sub-directory. Using bash from a remote terminal I try to execute each of the files (from the sub-directories) but all I get is:
root@beaglebone:~/opt/Eltima/eveusb/bin# eveusbc
-bash: eveusbc: command not found
I assume to execute I only need to type their names? Also I assume they are executable?
Any ideas please? Thanks.
