Compilation problem - DirectFB with bitbake -
Hi Everybody,
I want to compile DirectFB to run on BB with using bitbake but I face some errors. When I run the command bellow, I’m facing error on configure step;
bitbake -c compile -b directfb_1.4.1
error;
only use -b when you know what you are doing.
Op 15 okt 2009 om 08:48 heeft Bora Tunçer <boratuncer@gmail.com> het volgende geschreven:\
Thank you for help.
Which gfx driver should we choose in order to use SGX under DirectFB ? Can any body comment on this ?
Best Regards,
Bora
