I'm trying to compile Angstrom (via Openembedded) with floating point
optimizations how recommended on http://pandorawiki.org/Floating_Point_Optimization.
I read in one of Koen Kooi's posts(http://groups.google.com/group/
beagleboard/msg/909c4c3b3ab74116), that it should be sufficient to
add
ARM_FP_MODE = "hardfp"
in my local.conf. Without the above line the building process
terminate successfully, if I compile the base image (oebb.sh bitbake
base-image).
Unfortunately the task gcc-cross-initial-4.3.3-r23.2 failed, if I
activate hardfp. Error log:
make[2]: Leaving directory `/home/olaf/beagleboard/angstrom/jan2011/
angstrom-setup-scripts/build/tmp-angstrom_2008_1/work/armv7a-hardfp-
angstrom-linux-gnueabi/gcc-cross-initial-4.3.3-r23.2/gcc-4.3.3/
build.i686-linux.arm-angstrom-linux-gnueabi/gcc'
Checking multilib configuration for libgcc...
Configuring in arm-angstrom-linux-gnueabi/libgcc
configure: loading cache ./config.cache
checking for --enable-version-specific-runtime-libs... no
checking for a BSD-compatible install... /home/olaf/beagleboard/
angstrom/jan2011/angstrom-setup-scripts/sources/openembedded/bin/
install -c
checking for gawk... gawk
checking build system type... i686-pc-linux-gnu
checking host system type... arm-angstrom-linux-gnueabi
checking for arm-angstrom-linux-gnueabi-ar... /home/olaf/beagleboard/
angstrom/jan2011/angstrom-setup-scripts/build/tmp-angstrom_2008_1/
sysroots/i686-linux/usr/armv7a-hardfp/arm-angstrom-linux-gnueabi/bin/
ar
checking for arm-angstrom-linux-gnueabi-lipo... arm-angstrom-linux-
gnueabi-lipo
checking for arm-angstrom-linux-gnueabi-nm... /home/olaf/beagleboard/
angstrom/jan2011/angstrom-setup-scripts/build/tmp-angstrom_2008_1/work/
armv7a-hardfp-angstrom-linux-gnueabi/gcc-cross-initial-4.3.3-r23.2/
gcc-4.3.3/build.i686-linux.arm-angstrom-linux-gnueabi/./gcc/nm
checking for arm-angstrom-linux-gnueabi-ranlib... /home/olaf/
beagleboard/angstrom/jan2011/angstrom-setup-scripts/build/tmp-
angstrom_2008_1/sysroots/i686-linux/usr/armv7a-hardfp/arm-angstrom-
linux-gnueabi/bin/ranlib
checking for arm-angstrom-linux-gnueabi-strip... /home/olaf/
linux-gnueabi/bin/strip
checking whether ln -s works... yes
checking for arm-angstrom-linux-gnueabi-gcc... /home/olaf/beagleboard/
gcc-4.3.3/build.i686-linux.arm-angstrom-linux-gnueabi/./gcc/xgcc -B/
home/olaf/beagleboard/angstrom/jan2011/angstrom-setup-scripts/build/
tmp-angstrom_2008_1/work/armv7a-hardfp-angstrom-linux-gnueabi/gcc-
cross-initial-4.3.3-r23.2/gcc-4.3.3/build.i686-linux.arm-angstrom-
linux-gnueabi/./gcc/ -march=armv7-a -mtune=cortex-a8 -mfpu=neon -
mfloat-abi=hard -mthumb-interwork -mno-thumb -isystem/home/olaf/
angstrom_2008_1/sysroots/armv7a-hardfp-angstrom-linux-gnueabi/usr/
include -B/home/olaf/beagleboard/angstrom/jan2011/angstrom-setup-
scripts/build/tmp-angstrom_2008_1/sysroots/i686-linux/usr/armv7a-
hardfp/arm-angstrom-linux-gnueabi/bin/ -B/home/olaf/beagleboard/
sysroots/i686-linux/usr/armv7a-hardfp/arm-angstrom-linux-gnueabi/lib/ -
isystem /home/olaf/beagleboard/angstrom/jan2011/angstrom-setup-scripts/
build/tmp-angstrom_2008_1/sysroots/i686-linux/usr/armv7a-hardfp/arm-
angstrom-linux-gnueabi/include -isystem /home/olaf/beagleboard/
sysroots/i686-linux/usr/armv7a-hardfp/arm-angstrom-linux-gnueabi/sys-
include
checking for suffix of object files... configure: error: cannot
compute suffix of object files: cannot compile
See `config.log' for more details.
make[1]: *** [configure-target-libgcc] Error 1
make[1]: Leaving directory `/home/olaf/beagleboard/angstrom/jan2011/
build.i686-linux.arm-angstrom-linux-gnueabi'
make: *** [all] Error 2
FATAL: oe_runmake failed
ERROR: Function do_compile failed
I'm not sure, how to interpret the error message.
It.s necessary (and sufficient) to switch to an external toolchain
like csl2009q1 or use gcc4.5 as internal toolchain, which both support
the option -mfloat-abi=hard?
Thanks in advance,
Olaf Schulz
You also need to set DISTRO to angstrom-2010.x
Hello Koen,
thanks for this hint
With DISTRO="angstrom-2010.x" will most of the code complied.
It runs till u-boot_git.bb fails. Has anybody an idea, how to fix
this?
I assume the errors in the lines after
make[1]: Entering directory `/home/olaf/beagleboard/angstrom/jan2011/
angstrom-setup-scripts/build/tmp-angstrom_2008_1/work/beagleboard-
angstrom-linux-gnueabi/u-
boot-2010.03+r70+gitrca6e1c136ddb720c3bb2cc043b99f7f06bc46c55-r70/git/
tools/env'
/tmp-angstrom_2008_1/work/beagleboard-angstrom-linux-gnueabi/u-
include crc32.c fw_env.c fw_env_main.c -o fw_printenv
occurs, because fw_printenv wasn't created. But I can not detect the
reason.
Or is
'fatal: No names found, cannot describe anything.'
the culprit? I'm not well versed in git.
Thanks in advance
Olaf Schulz
Log:
NOTE: make CROSS_COMPILE=arm-angstrom-linux-gnueabi- all
Generating include/autoconf.mk
Generating include/autoconf.mk.dep
for dir in tools examples/standalone examples/api cpu/arm_cortexa8 /
cpu/arm_cortexa8/ ; do \
make -C $dir _depend ; done
tools'
tools'
tools'
make[1]: Nothing to be done for `_depend'.
arm-angstrom-linux-gnueabi-objcopy -O srec u-boot u-boot.srec
arm-angstrom-linux-gnueabi-objcopy --gap-fill=0xff -O binary u-boot u-
boot.bin
NOTE: make CROSS_COMPILE=arm-angstrom-linux-gnueabi- tools env
tools'
tools'
examples/standalone'
examples/api'
examples/api'
cpu/arm_cortexa8'
cpu/arm_cortexa8'
cpu/arm_cortexa8'
cpu/arm_cortexa8'
make -C tools all
tools'
tools'
make -C tools/env all MTD_VERSION= || exit 1
tools/env'
ln -s ../../lib_generic/crc32.c crc32.c
tools/env'
tools/env'
arm-angstrom-linux-gnueabi-gcc -Wall -DUSE_HOSTCC -I/home/olaf/
/home/olaf/beagleboard/angstrom/jan2011/angstrom-setup-scripts/build/
tmp-angstrom_2008_1/sysroots/i686-linux/usr/armv7a-hardfp/lib/gcc/arm-
angstrom-linux-gnueabi/4.5.3/../../../../arm-angstrom-linux-gnueabi/
bin/ld: error: /tmp/ccxWId0R.o uses VFP register arguments,
fw_printenv does not
bin/ld: failed to merge target specific data of file /tmp/ccxWId0R.o
bin/ld: error: /tmp/ccyryatE.o uses VFP register arguments,
bin/ld: failed to merge target specific data of file /tmp/ccyryatE.o
bin/ld: error: /tmp/ccCS9d1q.o uses VFP register arguments,
bin/ld: failed to merge target specific data of file /tmp/ccCS9d1q.o
collect2: ld returned 1 exit status
make[1]: *** [fw_printenv] Error 1
tools/env'
make: *** [env] Error 1
