Compiling LEDblink
As a first BeagleBoard project (also my first Eclipse/Linux project), I'm attempting to build LEDblink as described in the tutorial here:
http://elinux.org/BeagleBoardEclipse
When I select Project -> Clean, I get the error:
make: *** [clean] Error 1 LEDblink line 0 C/C++ Problem
The tutorial says "it might give some errors the first time, because nothing is to be cleaned."
When I try the next step and select Project -> Build project, I get the error:
make: *** No rule to make target `LEDblink.o', needed by `LEDblink'. LEDblink line 0 C/C++ Problem
In Project > Properties, Location is:
/home/ja/workspace/LEDblink
and all four project files are in that location.
I welcome suggestions on what to do or where to look.
Jan
Hi Jan,
BeagleBoardEclipse - eLinux.org
I get an error message that the removal of *.o files fails due to missing *.o files. This is fine if there are no *.o files the first time.
the error:
What does happen if you navigate in a terminal window manually to /home/ja/workspace/LEDblink and call the make file manually? E.g.
cd /home/ja/workspace/LEDblink
make all
Are you sure you really created a new empty Makefile project in Eclipse and configured the additional three topics mentioned at above wiki page (disable automatic build, disable Scanner Configuration Builder, disable Scanner Configuration Builder)?
Best regards
Dirk
