Instructions for cross compiling PortAudio for a BeagleBoard XM
PortAudio is an easy to use cross platform audio API for that looks the
same on Mac, Windows, Linux, etc. More info on PortAudio here:
I started with a BeagleBoard XM Rev C1 running the Angstrom demo.
I then installed Ubuntu 11.10 on my Mac as a VMWare application:
<http://www.trendsigma.net/vmware/ubuntu1110t.html>
Installed ALSA development packet for the BeagleBoard target into my
cross compiler toolchain. In Ubuntu Linux enter:
su -
source /usr/local/angstrom/arm/environment-setup
opkg-target update
opkg-target install alsa-dev
I then downloaded the nightly snapshot of PortAudio V19 from:
<http://www.portaudio.com/download.html>
to a Work directory in a user account on Ubuntu.
Then I compiled it by entering in Ubuntu Linux:
cd ~/Work/portaudio
# the following is all on one line
CFLAGS="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp"
./configure --host=arm-angstrom-linux-gnueabi
--prefix=/usr/local/angstrom/arm --disable-shared
make
ls bin
You should end up with a bunch of test files in the bin folder.
I copied a test file from Ubuntu to my BeagleBoard using scp. You will
need to change the IP address and account name to match your setup.
scp bin/paex_sine phil@192.168.1.120:/home/phil/.
Then on the BeagleBoard, as root, I entered:
cd ~phil
./paex_sine
If you have speakers hooked up, then you should hear a sine wave play
for 5 seconds.
For your cross compiled BeagleBoard project, link directly with the
static library:
lib/.libs/libportaudio.a
If you have suggestions or corrections, please let me know.
Phil Burk
www.softsynth.com
