I am trying U-Boot from git by myself and followed this
http://dev.gentoo.org/~armin76/arm/beaglebone/install.xml
instructions.
The compilation fails with:
armv7a-unknown-linux-gnueabi-gcc -E -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x80100000 -DCONFIG_SPL_TEXT_BASE=0x402F0400 -I/home/mccramer/data/pools/pool01/BEAGLEBONE-GENTOO/U-BOOT/u-boot-am33x/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/armv7a-unknown-linux-gnueabi/4.6.3/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv5 -include /home/mccramer/data/pools/pool01/BEAGLEBONE-GENTOO/U-BOOT/u-boot-am33x/include/u-boot/u-boot.lds.h -ansi -D__ASSEMBLY__ -P - </home/mccramer/data/pools/pool01/BEAGLEBONE-GENTOO/U-BOOT/u-boot-am33x/arch/arm/cpu/armv7/u-boot.lds >u-boot.lds
UNDEF_SYM=`armv7a-unknown-linux-gnueabi-objdump -x board/ti/am335x/libam335x.o api/libapi.o arch/arm/cpu/armv7/libarmv7.o arch/arm/cpu/armv7/omap-common/libomap-common.o arch/arm/cpu/armv7/ti81xx/libti81xx.o arch/arm/lib/libarm.o common/libcommon.o disk/libdisk.o drivers/bios_emulator/libatibiosemu.o drivers/block/libblock.o drivers/dma/libdma.o drivers/fpga/libfpga.o drivers/gpio/libgpio.o drivers/hwmon/libhwmon.o drivers/i2c/libi2c.o drivers/input/libinput.o drivers/misc/libmisc.o drivers/mmc/libmmc.o drivers/mtd/libmtd.o drivers/mtd/nand/libnand.o drivers/mtd/onenand/libonenand.o drivers/mtd/spi/libspi_flash.o drivers/mtd/ubi/libubi.o drivers/net/libnet.o drivers/net/phy/libphy.o drivers/pci/libpci.o drivers/pcmcia/libpcmcia.o drivers/power/libpower.o drivers/rtc/librtc.o drivers/serial/libserial.o drivers/spi/libspi.o drivers/twserial/libtws.o drivers/usb/eth/libusb_eth.o drivers/usb/gadget/libusb_gadget.o drivers/usb/host/libusb_host.o drivers/usb/musb-new/libusb_musb-new.o drivers/usb/musb/libusb_musb.o drivers/usb/phy/libusb_phy.o drivers/video/libvideo.o drivers/watchdog/libwatchdog.o fs/cramfs/libcramfs.o fs/ext2/libext2fs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ubifs/libubifs.o fs/yaffs2/libyaffs2.o lib/libfdt/libfdt.o lib/libgeneric.o lib/lzma/liblzma.o lib/lzo/liblzo.o lib/zlib/libz.o net/libnet.o post/libpost.o | sed -n -e 's/.*\(__u_boot_cmd_.*\)/-u\1/p'|sort|uniq`; cd /home/mccramer/data/pools/pool01/BEAGLEBONE-GENTOO/U-BOOT/u-boot-am33x && armv7a-unknown-linux-gnueabi-ld -pie -T u-boot.lds -Bstatic -Ttext 0x80100000 $UNDEF_SYM arch/arm/cpu/armv7/start.o --start-group api/libapi.o arch/arm/cpu/armv7/libarmv7.o arch/arm/cpu/armv7/omap-common/libomap-common.o arch/arm/cpu/armv7/ti81xx/libti81xx.o arch/arm/lib/libarm.o common/libcommon.o disk/libdisk.o drivers/bios_emulator/libatibiosemu.o drivers/block/libblock.o drivers/dma/libdma.o drivers/fpga/libfpga.o drivers/gpio/libgpio.o drivers/hwmon/libhwmon.o drivers/i2c/libi2c.o drivers/input/libinput.o drivers/misc/libmisc.o drivers/mmc/libmmc.o drivers/mtd/libmtd.o drivers/mtd/nand/libnand.o drivers/mtd/onenand/libonenand.o drivers/mtd/spi/libspi_flash.o drivers/mtd/ubi/libubi.o drivers/net/libnet.o drivers/net/phy/libphy.o drivers/pci/libpci.o drivers/pcmcia/libpcmcia.o drivers/power/libpower.o drivers/rtc/librtc.o drivers/serial/libserial.o drivers/spi/libspi.o drivers/twserial/libtws.o drivers/usb/eth/libusb_eth.o drivers/usb/gadget/libusb_gadget.o drivers/usb/host/libusb_host.o drivers/usb/musb-new/libusb_musb-new.o drivers/usb/musb/libusb_musb.o drivers/usb/phy/libusb_phy.o drivers/video/libvideo.o drivers/watchdog/libwatchdog.o fs/cramfs/libcramfs.o fs/ext2/libext2fs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ubifs/libubifs.o fs/yaffs2/libyaffs2.o lib/libfdt/libfdt.o lib/libgeneric.o lib/lzma/liblzma.o lib/lzo/liblzo.o lib/zlib/libz.o net/libnet.o post/libpost.o board/ti/am335x/libam335x.o --end-group -L /usr/lib/gcc/armv7a-unknown-linux-gnueabi/4.6.3 -lgcc -Map u-boot.map -o u-boot
/usr/lib/gcc/armv7a-unknown-linux-gnueabi/4.6.3/libgcc.a(_dvmd_lnx.o): In function `__aeabi_ldiv0':
(.text+0x8): undefined reference to `raise'
armv7a-unknown-linux-gnueabi-ld: BFD (GNU Binutils) 2.22.90.20120727 assertion fail /var/tmp/portage/cross-armv7a-unknown-linux-gnueabi/binutils-2.22.90/work/binutils-2.22.90/bfd/elf32-arm.c:7677
armv7a-unknown-linux-gnueabi-ld: error: required section '.rel.plt' not found in the linker script
armv7a-unknown-linux-gnueabi-ld: final link failed: Invalid operation
make: *** [u-boot] Error 1
[1] 18806 exit 2 make -j1 ARCH=arm CROSS_COMPILE=armv7a-unknown-linux-gnueabi-
...seems to be the final step.
If this is only a temporary bug cause the git conatins some buggy
code...no problem.
If I did something wrong or be able to fix it I would like to know,
what goes wrong...?!?
What is this ".rel.plt" file ?
Thank you very much in advance for any help !
Best regards,
mcc
instructions.
UNDEF_SYM=armv7a-unknown-linux-gnueabi-objdump -x board/ti/am335x/libam335x.o api/libapi.o arch/arm/cpu/armv7/libarmv7.o arch/arm/cpu/armv7/omap-common/libomap-common.o arch/arm/cpu/armv7/ti81xx/libti81xx.o arch/arm/lib/libarm.o common/libcommon.o disk/libdisk.o drivers/bios_emulator/libatibiosemu.o drivers/block/libblock.o drivers/dma/libdma.o drivers/fpga/libfpga.o drivers/gpio/libgpio.o drivers/hwmon/libhwmon.o drivers/i2c/libi2c.o drivers/input/libinput.o drivers/misc/libmisc.o drivers/mmc/libmmc.o drivers/mtd/libmtd.o drivers/mtd/nand/libnand.o drivers/mtd/onenand/libonenand.o drivers/mtd/spi/libspi_flash.o drivers/mtd/ubi/libubi.o drivers/net/libnet.o drivers/net/phy/libphy.o drivers/pci/libpci.o drivers/pcmcia/libpcmcia.o drivers/power/libpower.o drivers/rtc/librtc.o drivers/serial/libserial.o drivers/spi/libspi.o drivers/twserial/libtws.o drivers/usb/eth/libusb_eth.o drivers/usb/gadget/libusb_gadget.o drivers/usb/host/libusb_host.o drivers/usb/musb-new/libusb_musb-new.o drivers/usb/musb/libusb_musb.o drivers/usb/phy/libusb_phy.o drivers/video/libvideo.o drivers/watchdog/libwatchdog.o fs/cramfs/libcramfs.o fs/ext2/libext2fs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ubifs/libubifs.o fs/yaffs2/libyaffs2.o lib/libfdt/libfdt.o lib/libgeneric.o lib/lzma/liblzma.o lib/lzo/liblzo.o lib/zlib/libz.o net/libnet.o post/libpost.o | sed -n -e 's/.*\(__u_boot_cmd_.*\)/-u\1/p'|sort|uniq
/usr/lib/gcc/armv7a-unknown-linux-gnueabi/4.6.3/libgcc.a(_dvmd_lnx.o): In function __aeabi_ldiv0': (.text+0x8): undefined reference to
raise’
armv7a-unknown-linux-gnueabi-ld: error: required section ‘.rel.plt’ not found in the linker script
…seems to be the final step.
code…no problem.
what goes wrong…?!?
What is this “.rel.plt” file ?
Best regards,
mcc
On August 24, 2012, I successfully cross compiled u-boot on Gentoo. The version I have is:
commit 5c0406ddff69cd0b3d5271ba5cd98b44eac39c6e
Author: Joel A Fernandes <[xxx]@ti.com>
AM33XX: boot commands for booting from emmc on mmc1
You may want to post your question in the Gentoo forum Gentoo on Alternative Architectures
John Laurence Poole <jlpoole56@gmail.com> [12-09-07 00:16]:
