All,
I’m using the beagle bone to get back into computing so I’m new at Linux. I just powered up my Beagle Bone Black and got it connected to my MAC via SSH. I’m in via root and have the following prompt:
Last login: Wed Apr 23 20:20:36 2014 from 192.168.7.1
root@beaglebone:~#
I’m able to run some basic commands but am not seeing any directory structures or files. Is this correct or am I missing something?
Thoughts?
It’s correct. The “~” in “root@beaglebone:~#” indicates that you are in the home directory, which starts out empty. if you do " cd …", “ls” then you will see the standard directories.
You need to get yourself a good online tutorial. There are several.
For starters try, in this order:
cd /
ls -l
That will give a list of the files in the root file system. Kind of like C:\ in Windows
Good luck
“No one could make a greater mistake than he who did nothing because he could do only a little.”
“All that is necessary for the triumph of evil is that good men do nothing” Edmond Burke (1729 - 1797)
http://www.packtpub.com/building-a-home-security-system-with-beaglebone/book
