CONFIG_OMAP2_DSS_FAKE_VSYNC
I thought CONFIG_OMAP2_DSS_FAKE_VSYNC enables anm irq when a vsync
happens. So I enabled this option:
root@beagleboard:~# cat /proc/interrupts
           CPU0
12: 994 INTC DMA
25: 0 INTC OMAP DSS
56: 359 INTC i2c_omap
61: 0 INTC i2c_omap
74: 1447 INTC serial
I think OMAP DSS is this interrupt. But as one can see it is zero. Is
this option working with the new DSS2 driver?
Robert
           CPU0
12: 994 INTC DMA
25: 0 INTC OMAP DSS
61: 0 INTC i2c_omap
The option works, but is something totally different than what you are
looking for. It's meant for external display framebuffers, the option
can be used to create a fake VSYNC interrupt (as normally there's no
VSYNC with ext fbs).
Currently there's no way to get VSYNC from userspace. If you really
really want it, you can create a kernel module that registers to the
VSYNC interrupt from DSS, and then pass that to the userspace somehow.
I still don't know what would be the proper way for this. I don't see
any sensible way in the fb framework to do it.
Robert
Tomi
Okay, this is what I will try. Whats the irq-number of this interrupt
or how do I enable this interrupt?
The other solution is to use a gpio and blue-wire the signal from the
processor pin to a gpio on the expander slot. Thats the other way I am
thinking about.
Robert
Something like:
#include <mach/display.h>
void vsync_handler(void *arg, u32 mask)
  printk("vsync\n");
init()
  omap_dispc_register_isr(vsync_handler, 0, DISPC_IRQ_VSYNC);
uninit()
  omap_dispc_unregister_isr(vsync_handler);
thinking about.
Robert
Tomi
Thanks - it works!
Robert
