confusion about max supported HDMI monitor resolution on BBB
(definitely a question for gerald. :slight_smile:
  currently, BBB SRM, section 6.9, "HDMI Interface", states in section
6.9.1, "The maximum resolution supported by the BeagleBone Black is
1280x1024@60Hz". but the table right beneath that lists a supported
resolution of 1280x1024@75Hz. this seems slightly confusing.
  also, once upon a time, gerald explained the max resolution was
limited by the pix clock rate of the framer (125 MHz):
https://groups.google.com/forum/?fromgroups=#!topic/beagleboard/4vge3Zs8dYE
i was poking around and ran across the specs page of what looks to be
that framer here:
http://www.nxp.com/products/interface_and_connectivity/hdmi/hdmi_transmitters/TDA19988BET.html#overview
which states that (perhaps for a slightly different model) the clock
rate is 150MHz.
  i can see that that's the HDCP version of the framer, and gerald was
very clear that the BBB uses the *non*-HDCP version. but what's the
actual clock rate of the one on the BBB? thanks.
rday
p.s. unsurprisingly, i've started a BBB HDMI page to keep track of
stuff:
http://www.crashcourse.ca/wiki/index.php/HDMI_on_the_BBB
open to suggestions/additions.
