Hi Robert,
after having compile the image 4.9.6-bone4 I still cannot ssh to 192.168.1.1 so I have tried to switch back to 4.1.21-bone-rt-r20 by modifying the uEnv.txt and reboot then I get:
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
Error: “bootcmd_nand0” not defined
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 172.23.16.115 (99 ms)
Using cpsw device
TFTP from server 172.23.20.17; our IP address is 172.23.16.115; sending through gateway 172.23.16.254
Filename ‘\smsboot\x64\wdsnbp.com’.
Load address: 0x82000000
Loading: *###
2.7 MiB/s
done
Bytes transferred = 30832 (7870 hex)
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-78-a5-04-cc-37-c1
Using cpsw device
Filename ‘pxelinux.cfg/01-78-a5-04-cc-37-c1’.
Load address: 0x80100000
Loading: *
TFTP error: ‘Access violation.’ (4)
Starting again
Retrieving file: pxelinux.cfg/AC171073
Using cpsw device
Filename ‘pxelinux.cfg/AC171073’.
Loading: *
Starting again
Using cpsw device
Filename ‘pxelinux.cfg/AC1710’.
Loading: *
TFTP error: 'Access violation.
Is there a way to solve this ?
