Does anyone know what changes are required for Ubuntu to get an xM image running on the original Beagle Board? Is it just a matter or changing out uBoot? Or is it a really bad idea to try doing this, and I should just generate a whole new image for the Beagle Board original?
Cheers.
Ah, plug in the same card into the original BeagleBoard... As an xM
image is fully compatible with the original Beagle.. However, things
can get interesting when your still running an ancient bootloader on
the Beagle, so make sure you correctly update the older bootloader on
the original beagle..
