converting temperature from ADC
I don’t understand how to convert voltage in temperature.
My sensor is a IR temperature sensor with 5 V DC power supply (http://it.tinypic.com/r/dqfx37/9).
My beaglebone cannot support an output (0-5V) so I’ve used this voltage divider.
I’ve calculated the resistor R1=634 Ohm (5% so it’s not so good but it’s what I have now) and R2=324 Ohm (5%), considering an output max of 5.3V to scale to 1.8V.
So the conversion factor is (R2/(R1+R2))=0.34. So 1/0.34=2.94.
All it seems working. I can read with multimeter a voltage of 49/50mV in my room.
My running instead produces fluctuanting values between 20 to 65.
I read in python analog in this way:
import Adafruit_BBIO.ADC as ADC
import time
sensor_pin = ‘P9_40’
ADC.setup()
while True:
reading = ADC.read(sensor_pin)
millivolts = 2.94*(reading) #to obtain original voltage
temp_c = (millivolts) #here I’ve to obtain the correct slope to convert volts in degree
time.sleep(1)
Is it correct my code?
Thanks.
