I might try a raspberry pi, but I’m kind of worried that it’ll use the same USB stack and have the same issue. Might be worth a shot though.
It shouldn’t. But if you want flexibility in which distro you install I’d go with the rPI-2.
Alright, thanks for the help! I think I’ll order one of those.
Stephen,
Somewhat off topic. But if you plan on blogging, or just sharing your experiences, and / or project notes on that hackRF. Id be interesting in reading . . .
My buddy here has been an EE for a long time, and a professional radio station engineer. But as far as I know hes not worked with SDRs in this context so much. Anyway, we both have interest in that device of yours . . .
Sure, I did start to write about using the HackRF at http://blog.stephenpape.net/
I’ve actually completed that whole project (I can generate a signal to control a ceiling fan), but I’ve only written the first blog post about decoding the signal so far. I’ll cover generating the packet and synthesizing the signal when I get around to writing more.
-Stephen
Just to sort of close the loop, the HackRF is working for me with Arch Linux on the Raspberry Pi 2. Same code and setup, not even using a hub.
It’s a shame that the BBB doesn’t work, but I’m happy to be moving forward.
Thanks!
-Stephen
Hi Stephen,
have you used this device? https://greatscottgadgets.com/hackrf/
I’m experiencing this issue with some GSM modems. See my post at TI forum (http://e2e.ti.com/support/arm/sitara_arm/f/791/p/385033/1801121#1801121)
Yegor
Hi Yegor,
I’m not sure what you’re asking. The post you’re replying to is literally me talking about trying to get the HackRF working, so yes I’ve used it.
-Stephen
Hi Stephen,
Yegor
Hi Stephen,
there a multiple HackRF compatible devices, so I just wanted to know, what particular device you were using.
Yegor
